4 Replies Latest reply on May 15, 2016 11:16 PM by patilpralhad
    Save .ai file as .svg without save as prompt
    patilpralhad Level 1
      Hi All,
      I have a scenario where I want to save .ai document as .svg silently(without save as dialog) in the background. I'm using following code to do this. But it is giving save as dialog.
        sAIActionManager->AIActionSetStringUS(paramValue, kAIExportDocumentNameKey,ai::UnicodeString("test.svg"));
        sAIActionManager->AIActionSetString(paramValue, kAIExportDocumentExtensionKey,kAISVGFileFormatExtension);
        sAIActionManager->PlayActionEvent(kAIExportDocumentAction,kDialogOff,paramValue);
      Is there anything I'm doing wrong?
      If anyone knows how to do this kindly post code snippet or technique on how to do it.
      Thank you for your help
        • 1. Re: Save .ai file as .svg without save as prompt
          dnyaneshlb Level 1
          I have this snippet do exact thing you want. Though it uses extend-script and not c++.
          This does not give you save as dialogue.
          // Exports current document to dest as an SVG file with specified
          // options, dest contains the full path including the file name
          function exportFileToSVG (dest) {
          if ( app.documents.length > 0 ) {
          var exportOptions = new ExportOptionsSVG();
          var type = ExportType.SVG;
          var fileSpec = new File(dest);
          exportOptions.embedRasterImages = true;
          exportOptions.embedAllFonts = false;
          exportOptions.fontSubsetting = SVGFontSubsetting.GLYPHSUSED;
          app.activeDocument.exportFile( fileSpec, type, exportOptions );
          I hope this helps.
          • 2. Re: Save .ai file as .svg without save as prompt
            Toto RoToTO Level 3
            This few methods should help! Using Value parameter block (VPB) - a container for action parameters.
            @see AIActionManagerSuite
            void ActionHelper::VPB::SetSaveDocumentAsName(const ai::FilePath& name)
                SDK_ASSERT(sAIActionManager);
                ASErr result = sAIActionManager->AIActionSetStringUS(this->fActionParamValueRef, kAISaveDocumentAsNameKey,    name.GetFullPath());
                aisdk::check_ai_error(result);
            void ActionHelper::VPB::SetSaveDocumentAsGetParams(ASBoolean getParams)
                ASErr result = sAIActionManager->AIActionSetBoolean(this->fActionParamValueRef, kAISaveDocumentAsGetParamsKey, getParams);
            ASErr ActionHelper::SaveDocumentAs(const ai::UnicodeString& name, DocumentActionHelper::VPB& vpb)
                ASErr result = kNoErr;
                try {
                    ai::FilePath path(name);
                    vpb.SetSaveDocumentAsName(path);
                    // Enable dialogs parameter.
                    vpb.SetSaveDocumentAsGetParams(false);
                    ActionDialogStatus dialogStatus = name.empty() ? kDialogOn : kDialogOff;
                    result = this->SaveDocumentAs(dialogStatus, vpb);
                catch (ai::Error& ex) {
                    result = ex;
                return result;
            ASErr ActionHelper::SaveDocumentAs(ActionDialogStatus dialogStatus, AIActionParamValueRef parameters)
                try
                    result = sAIActionManager->PlayActionEvent(kAISaveDocumentAsAction, dialogStatus, parameters);
                    result = ex;
                return result;
            • 3. Re: Save .ai file as .svg without save as prompt
              Toto RoToTO Level 3
              the path you want to save your file is not correctly formatted, I guess. That is why dialogbox is shown.
              Try to fix this first!
              • 4. Re: Save .ai file as .svg without save as prompt
                So here is code snippet to do this. I had to do export file instead of save as.
                  AIActionParamValueRef paramValueRef = NULL;
                  sAIActionManager->AINewActionParamValue(&paramValueRef);
                  ai::UnicodeString name = ai::UnicodeString("C:\\Users\\mypc\\Desktop\\test\\testfile.svg");
                  sAIActionManager->AIActionSetStringUS(paramValueRef, kAIExportDocumentNameKey,path.GetFullPath());
                  sAIActionManager->AIActionSetString(paramValueRef, kAIExportDocumentFormatKey, kAISVGFileFormat);
                  sAIActionManager->AIActionSetString(paramValueRef, kAIExportDocumentExtensionKey, kAISVGFileFormatExtension);
                  sAIActionManager->AIActionSetBoolean(paramValueRef, kAIExportDocumentSaveMultipleArtboardsKey, false);
                  sAIActionManager->PlayActionEvent(kAIExportDocumentAction,  kDialogOff,  paramValueRef);
