0 Replies Latest reply on May 13, 2016 11:12 AM by jkustan1
    Mask/Motion Blur rendering bug
    jkustan1
      Hi, I ran into a very weird problem with exporting from AE CC (2015 13.7.2.3), and thought I'd see if anyone else has had this issue/can discover why its happening! I found a "workaround" that solved the problem for me, but which could potentially cause problems for other people.
      I have a series of masks in a composition.  When I render the comp using the Media Encoder, the mask looks correct:
      But when I try to render as an MOV directly through after effects ("Best Settings", "Lossless") the mask "shifts" for a few frames
      After a lot of hair-pulling, I finally discovered that the mask renders correctly when the "Motion Blur" setting is turned to "Off" - here is the setting in its default position.  Note that I have NO motion blurs on any of my layers, anywhere in my comp - so this setting would not solve the issue for someone who needed motion blur turned on:
      Anyone else run into this issue, or come up with a different solution?
