2 Replies Latest reply on May 14, 2016 12:21 PM by Critesta
    Lightroom CC 6.5.1 crash at startup
    Critesta
      Hello.
      I'm experiencing a strange Lightroom CC 6.5.1 behaviour that hangs at startup with no error messages on a Windows 7 Professional 64bit OS.
      I found two errors in the event log (I'm sorry but most of the error messages are in italian)
      This error appeared just after the installation of a Reflecta RPS 10M Scanner and the SilverFast AI Studio scanner software, but I'm pretty sure it depends on the scanner drivers: if install the scanner software nothing happens even if I run it and Lightroom still runs fine, but when i turn on the scanner and the driver gets installed Lightroom starts to hang immediately. The unistallation of the scanner software and the removal of the device don't solve the problem.
      Do someone experienced the same issue and solved or has an idea how to solve it?
      Thank you.
      Some details:
      The scanner is recognized as "Multiple frames film scanner"  (Film Scanner WIA Vendor) and uses the following drivers:
      DriverManufacturerVersion
      C:\Windows\system32\drivers\ksthunk.sys Microsoft6.1.7600.16385 (win7_rtm.090713-1255)
      C:\Windows\system32\drivers\usbscan.sysMicrosoft6.1.7601.18199 (win7sp1_gdr.130702-1534)
      C:\Windows\system32\drivers\MF5000_x64.dllPIE0.9.2.0
      C:\Windows\system32\drivers\msvcr110.dllMicrosoft11.00.50727.1 built by RTMREL
      C:\Windows\system32\drivers\PIEWiaScnr.dllWindows Win 7 DDK Provider6.2.9200.16384
      The first event:
      Nome dell'applicazione che ha generato l'errore: lightroom.exe, versione: 6.5.1.10, timestamp: 0x571b61a0
      Nome del modulo che ha generato l'errore: MSVCR120.dll, versione: 12.0.21005.1, timestamp: 0x524f83ff
      Codice eccezione: 0x40000015
      Offset errore 0x0000000000074a46
      ID processo che ha generato l'errore: 0x1e3c
      Ora di avvio dell'applicazione che ha generato l'errore: 0x01d1ade851855831
      Percorso dell'applicazione che ha generato l'errore: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
      Percorso del modulo che ha generato l'errore: C:\Program Files\Adobe\Adobe Lightroom\MSVCR120.dll
      ID segnalazione: 90bf97c2-19db-11e6-8bdf-bc5ff4513f4c
      EventData
      lightroom.exe
      6.5.1.10
      571b61a0
      MSVCR120.dll
      12.0.21005.1
      524f83ff
      40000015
      0000000000074a46
      1e3c
      01d1ade851855831
      It is followed by another event:
      Bucket errato 204388276, tipo 28
      Nome evento: APPCRASH
      Risposta: Non disponibile
      ID CAB: 0
      Firma problema:
      P1: lightroom.exe
      P2: 6.5.1.10
      P3: 571b61a0
      P4: MSVCR120.dll
      P5: 12.0.21005.1
      P6: 524f83ff
      P7: 40000015
      P8: 0000000000074a46
      P9:
      P10:
      The WER report I found says:
      Version=1
      EventType=APPCRASH
      EventTime=131077077509186371
      ReportType=2
      Consent=1
      UploadTime=131077077510786374
      ReportIdentifier=90bf97c3-19db-11e6-8bdf-bc5ff4513f4c
      IntegratorReportIdentifier=90bf97c2-19db-11e6-8bdf-bc5ff4513f4c
      Response.BucketId=204388276
      Response.BucketTable=28
      Response.type=4
      Sig[0].Name=Nome applicazione
      Sig[0].Value=lightroom.exe
      Sig[1].Name=Versione applicazione
      Sig[1].Value=6.5.1.10
      Sig[2].Name=Timestamp applicazione
      Sig[2].Value=571b61a0
      Sig[3].Name=Nome modulo con errori
      Sig[3].Value=MSVCR120.dll
      Sig[4].Name=Versione modulo con errori
      Sig[4].Value=12.0.21005.1
      Sig[5].Name=Timestamp modulo con errori
      Sig[5].Value=524f83ff
      Sig[6].Name=Codice eccezione
      Sig[6].Value=40000015
      Sig[7].Name=Offset eccezione
      Sig[7].Value=0000000000074a46
      DynamicSig[1].Name=Versione SO
      DynamicSig[1].Value=6.1.7601.2.1.0.256.48
      DynamicSig[2].Name=ID impostazioni locali
      DynamicSig[2].Value=1040
      DynamicSig[22].Name=Informazioni aggiuntive 1
      DynamicSig[22].Value=0133
      DynamicSig[23].Name=Ulteriori informazioni 2
      DynamicSig[23].Value=0133ab70a08f7ec2da18403ad9fb0964
      DynamicSig[24].Name=Ulteriori informazioni 3
      DynamicSig[24].Value=77cb
      DynamicSig[25].Name=Ulteriori informazioni 4
      DynamicSig[25].Value=77cb7b21014e5535664c514d008f3b02
      UI[2]=C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
      UI[3]=Adobe Photoshop Lightroom ha smesso di funzionare
      UI[4]=Windows: è possibile ricercare online una soluzione al problema.
      UI[5]=Cerca una soluzione online e chiudi il programma
      UI[6]=Cerca una soluzione online in seguito e chiudi il programma
      UI[7]=Chiudi il programma
      LoadedModule[0]=C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
      LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
      LoadedModule[2]=C:\Windows\system32\kernel32.dll
      LoadedModule[3]=C:\Windows\system32\KERNELBASE.dll
      LoadedModule[4]=C:\Program Files\Adobe\Adobe Lightroom\amtlib.dll
      LoadedModule[5]=C:\Windows\system32\IPHLPAPI.DLL
      LoadedModule[6]=C:\Windows\system32\msvcrt.dll
      LoadedModule[7]=C:\Windows\system32\NSI.dll
      LoadedModule[8]=C:\Windows\system32\WINNSI.DLL
      LoadedModule[9]=C:\Windows\system32\RPCRT4.dll
      LoadedModule[10]=C:\Windows\system32\WINHTTP.dll
      LoadedModule[11]=C:\Windows\system32\webio.dll
      LoadedModule[12]=C:\Windows\system32\SETUPAPI.dll
      LoadedModule[13]=C:\Windows\system32\CFGMGR32.dll
      LoadedModule[14]=C:\Windows\system32\ADVAPI32.dll
      LoadedModule[15]=C:\Windows\SYSTEM32\sechost.dll
      LoadedModule[16]=C:\Windows\system32\GDI32.dll
      LoadedModule[17]=C:\Windows\system32\USER32.dll
      LoadedModule[18]=C:\Windows\system32\LPK.dll
      LoadedModule[19]=C:\Windows\system32\USP10.dll
      LoadedModule[20]=C:\Windows\system32\OLEAUT32.dll
      LoadedModule[21]=C:\Windows\system32\ole32.dll
      LoadedModule[22]=C:\Windows\system32\DEVOBJ.dll
      LoadedModule[23]=C:\Windows\system32\SHLWAPI.dll
      LoadedModule[24]=C:\Windows\system32\SHELL32.dll
      LoadedModule[25]=C:\Program Files\Adobe\Adobe Lightroom\ui.dll
      LoadedModule[26]=C:\Program Files\Adobe\Adobe Lightroom\substrate.dll
      LoadedModule[27]=C:\Program Files\Adobe\Adobe Lightroom\AgKernel.dll
      LoadedModule[28]=C:\Windows\system32\WININET.dll
      LoadedModule[29]=C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
      LoadedModule[30]=C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
      LoadedModule[31]=C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
      LoadedModule[32]=C:\Windows\system32\version.DLL
      LoadedModule[33]=C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
      LoadedModule[34]=C:\Windows\system32\normaliz.DLL
      LoadedModule[35]=C:\Windows\system32\iertutil.dll
      LoadedModule[36]=C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
      LoadedModule[37]=C:\Windows\system32\USERENV.dll
      LoadedModule[38]=C:\Windows\system32\profapi.dll
      LoadedModule[39]=C:\Windows\system32\WS2_32.dll
      LoadedModule[40]=C:\Program Files\Adobe\Adobe Lightroom\MSVCR120.dll
      LoadedModule[41]=C:\Program Files\Adobe\Adobe Lightroom\MSVCP120.dll
      LoadedModule[42]=C:\Windows\system32\AUTHZ.dll
      LoadedModule[43]=C:\Program Files\Adobe\Adobe Lightroom\wichitafoundation.dll
      LoadedModule[44]=C:\Program Files\Adobe\Adobe Lightroom\LIBEAY32.dll
      LoadedModule[45]=C:\Program Files\Adobe\Adobe Lightroom\mfc120u.dll
      LoadedModule[46]=C:\Windows\system32\IMM32.dll
      LoadedModule[47]=C:\Windows\system32\MSCTF.dll
      LoadedModule[48]=C:\Windows\system32\UxTheme.dll
      LoadedModule[49]=C:\Windows\system32\CRYPT32.dll
      LoadedModule[50]=C:\Windows\system32\MSASN1.dll
      LoadedModule[51]=C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.76 01.23407_none_14556c1e8b95d0b8\gdiplus.dll
      LoadedModule[52]=C:\Windows\system32\DWrite.dll
      LoadedModule[53]=C:\Windows\system32\d2d1.dll
      LoadedModule[54]=C:\Windows\system32\Secur32.dll
      LoadedModule[55]=C:\Windows\system32\SSPICLI.DLL
      LoadedModule[56]=C:\Windows\system32\COMDLG32.dll
      LoadedModule[57]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1d f_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll
      LoadedModule[58]=C:\Windows\system32\urlmon.dll
      LoadedModule[59]=C:\Windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll
      LoadedModule[60]=C:\Program Files\Adobe\Adobe Lightroom\libcef.dll
      LoadedModule[61]=C:\Windows\system32\PSAPI.DLL
      LoadedModule[62]=C:\Windows\system32\WINSPOOL.DRV
      LoadedModule[63]=C:\Windows\system32\dhcpcsvc.DLL
      LoadedModule[64]=C:\Windows\system32\WTSAPI32.dll
      LoadedModule[65]=C:\Windows\system32\OLEACC.dll
      LoadedModule[66]=C:\Windows\system32\WINMM.dll
      LoadedModule[67]=C:\Windows\system32\dwmapi.dll
      LoadedModule[68]=C:\Windows\system32\WinTab32.dll
      LoadedModule[69]=C:\Windows\system32\CRYPTBASE.dll
      LoadedModule[70]=C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll
      LoadedModule[71]=C:\Windows\system32\CLBCatQ.DLL
      LoadedModule[72]=C:\Windows\system32\propsys.dll
      LoadedModule[73]=C:\Windows\system32\ntmarta.dll
      LoadedModule[74]=C:\Windows\system32\WLDAP32.dll
      LoadedModule[75]=C:\Program Files\Adobe\Adobe Lightroom\WFCore.dll
      LoadedModule[76]=C:\Program Files\Adobe\Adobe Lightroom\WFSQLite.dll
      LoadedModule[77]=C:\Program Files\Adobe\Adobe Lightroom\WFWeb.dll
      LoadedModule[78]=C:\Program Files\Adobe\Adobe Lightroom\WFOzClient.dll
      LoadedModule[79]=C:\Program Files\Adobe\Adobe Lightroom\LightroomModels.dll
      LoadedModule[80]=C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P7\x64\IMSLib.dll
      LoadedModule[81]=C:\Program Files\Adobe\Adobe Lightroom\xml_toolkit.dll
      LoadedModule[82]=C:\Windows\system32\WindowsCodecs.dll
      LoadedModule[83]=C:\Windows\system32\wbem\wbemprox.dll
      LoadedModule[84]=C:\Windows\system32\wbemcomn.dll
      LoadedModule[85]=C:\Windows\system32\CRYPTSP.dll
      LoadedModule[86]=C:\Windows\system32\rsaenh.dll
      LoadedModule[87]=C:\Windows\system32\RpcRtRemote.dll
      LoadedModule[88]=C:\Windows\system32\wbem\wbemsvc.dll
      LoadedModule[89]=C:\Windows\system32\wbem\fastprox.dll
      LoadedModule[90]=C:\Windows\system32\NTDSAPI.dll
      LoadedModule[91]=C:\Windows\system32\apphelp.dll
      LoadedModule[92]=C:\Program Files\Adobe\Adobe Lightroom\updaternotifications.dll
      LoadedModule[93]=C:\Windows\system32\NETAPI32.dll
      LoadedModule[94]=C:\Windows\system32\netutils.dll
      LoadedModule[95]=C:\Windows\system32\srvcli.dll
      LoadedModule[96]=C:\Windows\system32\wkscli.dll
      LoadedModule[97]=C:\Windows\system32\taskschd.dll
      LoadedModule[98]=C:\Program Files\Adobe\Adobe Lightroom\catalog_converters.dll
      LoadedModule[99]=C:\Windows\system32\mssprxy.dll
      LoadedModule[100]=C:\Program Files\Adobe\Adobe Lightroom\CameraRaw.dll
      LoadedModule[101]=C:\Windows\system32\mscms.dll
      LoadedModule[102]=C:\Windows\system32\OPENGL32.dll
      LoadedModule[103]=C:\Windows\system32\GLU32.dll
      LoadedModule[104]=C:\Windows\system32\DDRAW.dll
      LoadedModule[105]=C:\Windows\system32\DCIMAN32.dll
      LoadedModule[106]=C:\Windows\system32\atig6pxx.dll
      LoadedModule[107]=C:\Windows\system32\atio6axx.dll
      LoadedModule[108]=C:\Windows\system32\atiadlxx.dll
      LoadedModule[109]=C:\Windows\system32\WINTRUST.dll
      LoadedModule[110]=C:\Windows\system32\atig6txx.dll
      LoadedModule[111]=C:\Program Files\Adobe\Adobe Lightroom\video_toolkit.dll
      LoadedModule[112]=C:\Program Files\Adobe\Adobe Lightroom\Import.lrmodule
      LoadedModule[113]=C:\Program Files\Adobe\Adobe Lightroom\bridgetalk.dll
      State[0].Key=Transport.DoneStage1
      State[0].Value=1
      State[1].Key=DataRequest
      State[1].Value=Bucket=204388276/nBucketTable=28/nResponse=1/n
      FriendlyEventName=Ha smesso di funzionare
      ConsentKey=APPCRASH
      AppName=Adobe Photoshop Lightroom
      AppPath=C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
      The second:
      Nome del modulo che ha generato l'errore: ntdll.dll, versione: 6.1.7601.23392, timestamp: 0x56eb3625
      Codice eccezione: 0xc000041d
      Offset errore 0x000000000004d7f6
      Percorso del modulo che ha generato l'errore: C:\Windows\SYSTEM32\ntdll.dll
      ID segnalazione: 95305fcb-19db-11e6-8bdf-bc5ff4513f4c
      EventData
      lightroom.exe
      6.5.1.10
      571b61a0
      ntdll.dll
      6.1.7601.23392
      56eb3625
      c000041d
      000000000004d7f6
      1e3c
      01d1ade851855831
      followed by the event:
      Bucket errato 204763155, tipo 28
      ID CAB: 0
      Firma problema:
      P1: lightroom.exe
      P2: 6.5.1.10
      P3: 571b61a0
      P4: ntdll.dll
      P5: 6.1.7601.23392
      P6: 56eb3625
      P7: c000041d
      P8: 000000000004d7f6
      P9:
      P10:
      The WER report:
      Version=1
      EventType=APPCRASH
      EventTime=131077077583386475
      ReportType=2
      Consent=1
      UploadTime=131077077584986478
      ReportIdentifier=95305fcc-19db-11e6-8bdf-bc5ff4513f4c
      IntegratorReportIdentifier=95305fcb-19db-11e6-8bdf-bc5ff4513f4c
      Response.BucketId=204763155
      Response.type=4
      Sig[3].Value=ntdll.dll
      Sig[4].Value=6.1.7601.23392
      Sig[5].Value=56eb3625
      Sig[6].Value=c000041d
      Sig[7].Value=000000000004d7f6
      DynamicSig[22].Value=d82b
      DynamicSig[23].Value=d82b1787502fddcffa5ccd31a283eefc
      DynamicSig[24].Value=ecfe
      DynamicSig[25].Value=ecfe3b3c36ad61bdd90babf68b5c3a8f
      State[0].Value=1
      State[1].Value=Bucket=204763155/nBucketTable=28/nResponse=1/n
      ConsentKey=APPCRASH
