3 Replies Latest reply on May 30, 2006 7:12 AM by Newsgroup_User
    export a fla as single swf files
    Level 7
      is there a hint or workaround how to export (save) all frames of a FLA file
      as single swf files (like
      you can export a FLA in single JPG files)?
      Would much appreciate if someone has a hint for me.
      Thank you in advanve
      Peter
        • 1. Re: export a fla as single swf files
          Level 7
          i may have missed your question - but this is a simple File > Publish Settings question - you can
          also Export as SWF - so not sure if you know this and are having problems? there are no work arounds
          to this as it is very basic flash procedure. Please re-explain if i didn't understand.
          --> **Adobe Certified Expert**
          --> www.mudbubble.com
          --> www.keyframer.com
          lollipop wrote:
          > Hi,
          > Peter
          • 2. Re: export a fla as single swf files
            Level 7
            that hint does'nt help. The problem is that I want to have all frames out of
            one FLA file stored as SINGLE swf file.
            Example: Source: test.fla with 5 frames exported to: test_001.swf,
            test_002.swf, test_003.swf ...
            Any idea how to do?
            Kind regards
            Peter
            "Chris Georgenes" <chris@REMOVEmudbubble.com> schrieb im Newsbeitrag
            news:e5f88q$83h$3@forums.macromedia.com...
            >Settings question - you can also Export as SWF - so not sure if you know
            >this and are having problems? there are no work arounds to this as it is
            > lollipop wrote:
            >> Hi,
            >> file as single swf files (like
            >> Peter
            • 3. Re: export a fla as single swf files
              Level 7
              Ah right - to be fair, your question (and even to some extent, your most
              recent post) are pretty unclear. You don't mean you want it exported as a
              single file - you want each frame as a *separate* SWF?
              You should look at:
              File>>Export>>Export Image
              I don;t think you can automate this easily. You may be able to do something
              with JSFL though
              Remove '_spamkiller_' to mail
