2 Replies Latest reply on May 30, 2006 1:25 AM by ramasatoskar
    how to create my own validations
    j2eesatish Level 1
      Hi I am using String validatins. But i want check some some conditions from my inoput. Is it posible to write my own validations for the components?
      And also can change the look of the validation alert style!.
        • 1. Re: how to create my own validations
          ramasatoskar
          Hi have u read adobe flex2.0 help files there are many topics related to it. Regarding validation the topics lie under the titles
          Creating and Extending Flex 2.0 Components > Creating Nonvisual Flex Components > Creating Custom Validators
          Moreover there is an example that examines three input fields:
          package myValidators
          import mx.validators.Validator;
          import mx.validators.ValidationResult;
          public class NameValidator extends Validator {
          // Define Array for the return value of doValidation().
          private var results:Array;
          public function NameValidator () {
          super();
          override protected function doValidation(value bject):Array {
          var fName:String = value.first;
          var mName:String = value.middle;
          var lName:String = value.last;
          // Clear results Array.
          results = [];
          // Call base class doValidation().
          results = super.doValidation(value);
          // Return if there are errors.
          if (results.length > 0)
          return results;
          // Check first name field.
          if (fName == "" || fName == null) {
          results.push(new ValidationResult(true, "first", "noFirstName",
          "No First Name."));
          return results;
          // Check middle name field.
          if (mName == "" || mName == null) {
          results.push(new ValidationResult(true, "middle", "noMiddleName",
          "No Middle Name."));
          return results;
          // Check last name field.
          if (lName == "" || lName == null) {
          results.push(new ValidationResult(true, "last", "noLastName",
          "No Last Name."));
          return results;
          return results;
          • 2. Re: how to create my own validations
            ramasatoskar Level 1
            Also in another example , you use a NameValidator that validates an item containing three fields named first, middle, and last:
            <?xml version="1.0"?>
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:MyComp="myValidators.*">
            <mx:Model id="person">
            <name>
            <first>{firstInput.text}</first>
            <middle>{middleInput.text}</middle>
            <last>{lastInput.text}</last>
            </name>
            </mx:Model>
            <mx:TextInput id="firstInput"/>
            <mx:TextInput id="middleInput"/>
            <mx:TextInput id="lastInput"/>
            <MyComp:NameValidator id="nameVal"
            source="{person}" property="name"
            listener="{firstInput}"/>
            <mx:Button label="Validate" click="nameVal.validate();"/>
            </mx:Application>
