0 Replies Latest reply on May 16, 2016 5:17 AM by pera65984855
    adobeGCClient.exe has stoped working
    pera65984855 Level 1
      I want to install CS6 inDesing and inCopy on a Virtualdisk(vdisk) For provisioing Citrix.
      I have installed CS6 inDesing and inCopy with Amee.
      I used:
      Installed Package.
      Default on the rest.
      Used Force install since it wouldn´t istall otherwise.
      all on a clean server.
      Have I then used the install packages to install on the image(installed in elevated cmd with "change user /install" and msiexec.exr /i "filepatch" ).
      And then booted up 2 serverns for test.
      I keep getting this error though when starting up Indesing:
      "adobeGCClient.exe has stoped working"
      problems signature:
         Problem Event Name: APPCRASH
         Program name: AdobeGCClient.exe
         Software Version: 2.6.0.81
         Application Timestamp: 57036768
         Name of sql_tokens: AdobeGCClient.exe
         Module Version: 2.6.0.81
         Timestamp sql_tokens: 57036768
         Exception code: C0000005
         Exceptions Displacement: 00004ada
         OS version: 6.1.7601.2.1.0.144.8
         Locale ID: 1053
         Additional information 1: e1a2
         Additional information 2: e1a2f30b2b561fd6f54c415ef35f6091
         Additional Information 3: a991
         More information 4: a99164710cf090a644e3f129352f68b2
      in Event viewer:
      Log Name: Application
      Source: Application Error
      Date: 2016-05-13 10:56:28
      Event ID: 1000
      Task Category: (100)
      Level: Error
      Keywords: Classical
      User missing
      Computer: hosting xapp09.hosting.local
      Description:
      The error occurred in the program by name: AdobeGCClient.exe, version 2.6.0.81, timestamp 0x57036768
      , The error occurred in the module with the name: unknown, version 0.0.0.0, time stamp 0x00000000
      Exemption code: 0xc0000005
      Felförskjutning: 0x0148d715
      Process ID: 0x13f4
      The program start time: 0x01d1acf55406aad0
      Path to the Program: C: \ Program Files (x86) \ Common Files \ Adobe \ AdobeGCClient \ AdobeGCClient.exe
      Path to the module: Unknown
      Report ID: 94217c6c-18e8-11e6-8846-005056b200b4
      Event XML data:
      <Event xmlns = "http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
          <Provider Name = "Application Error" />
          <Eventid Qualifiers = "0"> 1000 </ eventid>
          <Level> 2 </ level>
          <Task> 100 </ Task>
          <Keywords> 0x80000000000000 </ Keywords>
          <All Time System Time = "2016-05-13T08: 56: 28.000000000Z" />
          <EventRecordID> 43198 </ EventRecordID>
          <Channel> Application </ channel>
          <Computer> hosting xapp09.hosting.local </ Computer>
          <Security />
        </ System>
        <Event Data>
          <Data> AdobeGCClient.exe </ data>
          <Data> 2.6.0.81 </ data>
          <Data> 57036768 </ data>
          <Data> Unknown </ data>
          <Data> 0.0.0.0 </ data>
          <Data> 00000000 </ data>
          <Data> C0000005 </ data>
          <Data> 0148d715 </ data>
          <Data> 13f4 </ data>
          <Data> 01d1acf55406aad0 </ data>
          <Data> C: \ Program Files (x86) \ Common Files \ Adobe \ AdobeGCClient \ AdobeGCClient.exe </ data>
          <Data> 94217c6c-18e8-11e6-8846-005056b200b4 </ data>
        </ Event Data>
      </ Event>
      Source: Windows Error Reporting
      Date: 2016-05-13 10:56:35
      Event ID: 1001
      Task Category: None
      Level: Information
      Keywords: Classical
      User missing
      Description:
      Fault bucket, type 0
      Event Name: BEX
      Answer: Not Available
      Cabinet ID: 0
      Problem Signature:
      P1: AdobeGCClient.exe
      P2: 2.6.0.81
      P3: 57036768
      P4: StackHash_e98d
      P5: 0.0.0.0
      P6: 00000000
      P7: 0148d715
      P8: C0000005
      P9: 00000008
      P10:
      The files may be available at the following location:
      C:\Users\kastest\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_AdobeGCClient. ex_23f49b49682cf94ca51d16dff9bc746274ec8_1f5d95bb
      Analysis Symbol:
      Checks the solution again: 0
      Report Status: 0
      Event XML data:
        <System>
          <Provider Name = "Windows Error Reporting" />
          <Eventid Qualifiers = "0"> 1001 </ eventid>
          <Level> 4 </ level>
          <Task> 0 </ Task>
          <All Time System Time = "2016-05-13T08: 56: 35.000000000Z" />
          <EventRecordID> 43199 </ EventRecordID>
          <Security />
        </ System>
        <Event Data>
          <Data>
          </ Data>
          <Data> 0 </ data>
          <Data> BEX </ data>
          <Data> Unavailable </ data>
          <Data> 0 </ data>
          <Data> StackHash_e98d </ data>
          <Data> 00000008 </ data>
          <Data>
          </ Data>
          <Data>
          </ Data>
          <Data>C:\Users\kastest\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_AdobeGC Client.ex_23f49b49682cf94ca51d16dff9bc746274ec8_1f5d95bb</Data>
          <Data>
          </ Data>
          <Data> 0 </ data>
          <Data> 0 </ data>
        </ Event Data>
      </ Event>
      And from the Adobegc.log:
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library invoked = 2.6.0.81 ************
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4904 | Perform WF started
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4904 | Perform WF completed
      05/13/16 10:56:23:698 | [DEBUG] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Trying to acquire the semaphore
      05/13/16 10:56:23:698 | [DEBUG] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Semaphore acquired
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Threaded CFU Started
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4536 | Get client install path Started
      05/13/16 10:56:23:714 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4536 | Get client install path Ended
      05/13/16 10:56:23:714 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Client sanitization started
      05/13/16 10:56:23:886 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Signature found
      05/13/16 10:56:23:886 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Found valid signature, checking if signed by Adobe or not
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Signature found
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Client app successfully signed
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCVersionWrapper |  |  | 4536 | Get version for file Started
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCVersionWrapper |  |  | 4536 | Get version for file Ended
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Client sanitization ended
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Threaded CFU Ended
      05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Semaphore signalled
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library invoked = 2.6.0.81 ************
      05/13/16 10:56:24:698 | [DEBUG] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Trying to acquire the semaphore
      05/13/16 10:56:24:698 | [DEBUG] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Semaphore acquired
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Perform WF started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Get XML path Started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Create XML Started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding generic deails Started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding generic deails Ended
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding app deails Started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | App executable path C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | App Adobe code {CFB770D7-8D43-1014-922B-CC2715FADE3F}
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding app deails Ended
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Create XML Ended
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Storing XML Started
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Storing XML Ended
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Get XML path Ended
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Invoking GC client completed
      05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | Get client install path Started
      05/13/16 10:56:24:714 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | Get client install path Ended
      05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Invoking GC client completed
      05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Perform WF completed
      05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Semaphore signalled
      05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library End*******************
      05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | *********** Adobe GCClient Launched = 2.6.0.81 ************
      05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Initiating workflow
      05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Client request processing started
      05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Mutex acquired, continue with the workflow
      05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Initializing client workflow
      05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Trying to acquire the semaphore
      05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Semaphore acquired
      05/13/16 10:56:25:042 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode
      05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the app executable for LEID : InDesign-CS6-Win-GM
      05/13/16 10:56:25:073 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the amt lib path for LEID : InDesign-CS6-Win-GM
      05/13/16 10:56:25:089 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the adobe code for LEID : InDesign-CS6-Win-GM
      05/13/16 10:56:25:104 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode
      05/13/16 10:56:25:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] in master : 10
      05/13/16 10:56:25:245 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] from master db : 7
      05/13/16 10:56:25:245 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] in master : 10
      05/13/16 10:56:25:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] from master db : 7
      05/13/16 10:56:25:276 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] in master : 10
      05/13/16 10:56:25:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] from master db : 7
      05/13/16 10:56:25:308 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] in master : 10
      05/13/16 10:56:25:339 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] from master db : 7
      05/13/16 10:56:25:370 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] in master : 10
      05/13/16 10:56:25:401 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] from master db : 7
      05/13/16 10:56:25:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] in master : 10
      05/13/16 10:56:25:433 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] from master db : 7
      05/13/16 10:56:25:448 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] in master : 10
      05/13/16 10:56:25:464 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] from master db : 7
      05/13/16 10:56:25:464 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{08D2E121-7F6A-43EB-97FD-629B44903403}] from master : 5
      05/13/16 10:56:25:495 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{08D2E121-7F6A-43EB-97FD-629B44903403}] from master db : 7
      05/13/16 10:56:25:495 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] in master : 10
      05/13/16 10:56:25:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] from master db : 7
      05/13/16 10:56:25:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0AEC15F4-8EC3-4E2F-A5F0-6ABA39029D1B}] from master : 5
      05/13/16 10:56:25:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0AEC15F4-8EC3-4E2F-A5F0-6ABA39029D1B}] from master db : 7
      05/13/16 10:56:25:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0C4E7429-E920-4125-980E-029A87AE0A4D}] from master : 5
      05/13/16 10:56:25:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0C4E7429-E920-4125-980E-029A87AE0A4D}] from master db : 7
      05/13/16 10:56:25:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0E0AA043-65AC-4A20-AAD6-9B4C7667309B}] from master : 5
      05/13/16 10:56:25:604 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0E0AA043-65AC-4A20-AAD6-9B4C7667309B}] from master db : 7
      05/13/16 10:56:25:604 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{1EA52983-8EDD-1014-A956-E9729DA4AEEB}] from master : 5
      05/13/16 10:56:25:620 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{1EA52983-8EDD-1014-A956-E9729DA4AEEB}] from master db : 7
      05/13/16 10:56:25:636 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{24B187F6-7743-4EEC-8820-1B7374B6A4A2}] from master : 5
      05/13/16 10:56:25:651 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{24B187F6-7743-4EEC-8820-1B7374B6A4A2}] from master db : 7
      05/13/16 10:56:25:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{26F763C9-076F-473D-9A0E-4050C973737C}] from master : 5
      05/13/16 10:56:25:683 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{26F763C9-076F-473D-9A0E-4050C973737C}] from master db : 7
      05/13/16 10:56:25:683 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{2DAEE15D-8D47-1014-9FF6-ACA9093B5359}] from master : 5
      05/13/16 10:56:25:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{2DAEE15D-8D47-1014-9FF6-ACA9093B5359}] from master db : 7
      05/13/16 10:56:25:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] in master : 10
      05/13/16 10:56:25:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] from master db : 7
      05/13/16 10:56:25:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{354D20E6-A25F-4728-9DA6-C9003D8F2928}] from master : 5
      05/13/16 10:56:25:761 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{354D20E6-A25F-4728-9DA6-C9003D8F2928}] from master db : 7
      05/13/16 10:56:25:776 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{36682D68-3834-487E-BA49-DFA4AB0A2E32}] from master : 5
      05/13/16 10:56:25:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{36682D68-3834-487E-BA49-DFA4AB0A2E32}] from master db : 7
      05/13/16 10:56:25:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{373E3339-C141-4A99-A40A-77E28AFEF1B4}] from master : 5
      05/13/16 10:56:25:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{373E3339-C141-4A99-A40A-77E28AFEF1B4}] from master db : 7
      05/13/16 10:56:25:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{3871C312-24AC-4FCA-AD09-AD55E3237B98}] from master : 5
      05/13/16 10:56:25:839 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{3871C312-24AC-4FCA-AD09-AD55E3237B98}] from master db : 7
      05/13/16 10:56:25:839 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{39C798E1-96E1-1014-8C88-E90A74353141}] from master : 5
      05/13/16 10:56:25:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{39C798E1-96E1-1014-8C88-E90A74353141}] from master db : 7
      05/13/16 10:56:25:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{42C0738D-8D50-45B7-BC51-4BC609133E3A}] from master : 5
      05/13/16 10:56:25:886 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{42C0738D-8D50-45B7-BC51-4BC609133E3A}] from master db : 7
      05/13/16 10:56:25:886 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{4F38B549-96DF-1014-BBB1-C5F7191EB5AC}] from master : 5
      05/13/16 10:56:25:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{4F38B549-96DF-1014-BBB1-C5F7191EB5AC}] from master db : 7
      05/13/16 10:56:25:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{539AEF15-3A2B-4A31-A587-7E90F7D9C700}] from master : 5
      05/13/16 10:56:25:917 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{539AEF15-3A2B-4A31-A587-7E90F7D9C700}] from master db : 7
      05/13/16 10:56:25:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{544A2B1B-96E0-1014-B93E-8016F23F4105}] from master : 5
      05/13/16 10:56:25:948 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{544A2B1B-96E0-1014-B93E-8016F23F4105}] from master db : 7
      05/13/16 10:56:25:948 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{557F9FD3-EED8-43D7-AF29-0F19CA832728}] from master : 5
      05/13/16 10:56:25:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{557F9FD3-EED8-43D7-AF29-0F19CA832728}] from master db : 7
      05/13/16 10:56:25:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{5E0B469F-8D7F-1014-B892-BB4C1CDBC643}] from master : 5
      05/13/16 10:56:25:979 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{5E0B469F-8D7F-1014-B892-BB4C1CDBC643}] from master db : 7
      05/13/16 10:56:25:979 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{5EF99A9D-8D82-1014-9DEC-C24C3816749A}] from master : 5
      05/13/16 10:56:26:011 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{5EF99A9D-8D82-1014-9DEC-C24C3816749A}] from master db : 7
      05/13/16 10:56:26:011 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{60CCCE9D-8D78-1014-B66A-CEF4BA1DA4CD}] from master : 5
      05/13/16 10:56:26:042 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{60CCCE9D-8D78-1014-B66A-CEF4BA1DA4CD}] from master db : 7
      05/13/16 10:56:26:042 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] in master : 10
      05/13/16 10:56:26:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] from master db : 7
      05/13/16 10:56:26:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{7E91BB17-16A1-42CE-9502-D6C98BE04920}] from master : 5
      05/13/16 10:56:26:089 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{7E91BB17-16A1-42CE-9502-D6C98BE04920}] from master db : 7
      05/13/16 10:56:26:089 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{8467887D-92F1-435C-B387-A7551B88EC70}] from master : 5
      05/13/16 10:56:26:104 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{8467887D-92F1-435C-B387-A7551B88EC70}] from master db : 7
      05/13/16 10:56:26:104 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{8E562D5B-8D73-1014-8DE0-BF91B9118C53}] from master : 5
      05/13/16 10:56:26:136 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{8E562D5B-8D73-1014-8DE0-BF91B9118C53}] from master db : 7
      05/13/16 10:56:26:136 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] from master : 5
      05/13/16 10:56:26:151 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] from master db : 7
      05/13/16 10:56:26:167 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] in master : 10
      05/13/16 10:56:26:183 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] from master db : 7
      05/13/16 10:56:26:183 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] from master : 5
      05/13/16 10:56:26:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] from master db : 7
      05/13/16 10:56:26:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9B78FAB0-AC6B-11E0-8EF3-00215AEA26C9}] from master : 5
      05/13/16 10:56:26:229 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9B78FAB0-AC6B-11E0-8EF3-00215AEA26C9}] from master db : 7
      05/13/16 10:56:26:229 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] from master : 5
      05/13/16 10:56:26:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] from master db : 7
      05/13/16 10:56:26:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9D2A060F-AC6B-11E0-8C00-00215AEA26C9}] from master : 5
      05/13/16 10:56:26:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9D2A060F-AC6B-11E0-8C00-00215AEA26C9}] from master db : 7
      05/13/16 10:56:26:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] from master : 5
      05/13/16 10:56:26:323 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] from master db : 7
      05/13/16 10:56:26:323 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{A0F72081-99FB-4FFA-AE1A-62B5A656CAC1}] from master : 5
      05/13/16 10:56:26:354 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{A0F72081-99FB-4FFA-AE1A-62B5A656CAC1}] from master db : 7
      05/13/16 10:56:26:354 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{AA9DC298-8D46-1014-853D-9FC0306FBFCE}] from master : 5
      05/13/16 10:56:26:386 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{AA9DC298-8D46-1014-853D-9FC0306FBFCE}] from master db : 7
      05/13/16 10:56:26:386 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B306E604-6439-49B9-B5D1-07503AF3E553}] from master : 5
      05/13/16 10:56:26:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B306E604-6439-49B9-B5D1-07503AF3E553}] from master db : 7
      05/13/16 10:56:26:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B4D27704-ABF7-4FB4-A6CE-E69925B2A682}] from master : 5
      05/13/16 10:56:26:448 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B4D27704-ABF7-4FB4-A6CE-E69925B2A682}] from master db : 7
      05/13/16 10:56:26:479 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] in master : 10
      05/13/16 10:56:26:511 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] from master db : 7
      05/13/16 10:56:26:511 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B8CD128B-8D40-1014-B944-C86071713DAE}] from master : 5
      05/13/16 10:56:26:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8CD128B-8D40-1014-B944-C86071713DAE}] from master db : 7
      05/13/16 10:56:26:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B98E0DCB-1A75-4394-9813-3A114AA3891D}] from master : 5
      05/13/16 10:56:26:558 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B98E0DCB-1A75-4394-9813-3A114AA3891D}] from master db : 7
      05/13/16 10:56:26:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{BF667E23-0186-41F1-ACAE-5786D4B34F56}] from master : 5
      05/13/16 10:56:26:589 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{BF667E23-0186-41F1-ACAE-5786D4B34F56}] from master db : 7
      05/13/16 10:56:26:589 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{C7B1C1B3-368D-4C32-A818-83F1554EB398}] from master : 5
      05/13/16 10:56:26:620 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{C7B1C1B3-368D-4C32-A818-83F1554EB398}] from master db : 7
      05/13/16 10:56:26:636 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{CEAB7536-8D73-1014-B405-F76E131B0743}] from master : 5
      05/13/16 10:56:26:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{CEAB7536-8D73-1014-B405-F76E131B0743}] from master db : 7
      05/13/16 10:56:26:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{CFA46C39-C539-4BE9-9364-495003C714AD}] from master : 5
      05/13/16 10:56:26:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{CFA46C39-C539-4BE9-9364-495003C714AD}] from master db : 7
      05/13/16 10:56:26:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] from master : 5
      05/13/16 10:56:26:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] from master db : 7
      05/13/16 10:56:26:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{D9BB636C-8D4E-1014-BDA3-9FE36B5694FE}] from master : 5
      05/13/16 10:56:26:761 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{D9BB636C-8D4E-1014-BDA3-9FE36B5694FE}] from master db : 7
      05/13/16 10:56:26:776 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DB39A1C8-8D51-1014-B2A3-BFB7AE176AF6}] from master : 5
      05/13/16 10:56:26:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DB39A1C8-8D51-1014-B2A3-BFB7AE176AF6}] from master db : 7
      05/13/16 10:56:26:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] from master : 5
      05/13/16 10:56:26:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] from master db : 7
      05/13/16 10:56:26:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] in master : 10
      05/13/16 10:56:26:854 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] from master db : 7
      05/13/16 10:56:26:854 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DE88AA40-6766-43D3-A755-8FC374B3D2C3}] from master : 5
      05/13/16 10:56:26:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE88AA40-6766-43D3-A755-8FC374B3D2C3}] from master db : 7
      05/13/16 10:56:26:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85}] from master : 5
      05/13/16 10:56:26:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85}] from master db : 7
      05/13/16 10:56:26:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] from master : 5
      05/13/16 10:56:26:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] from master db : 7
      05/13/16 10:56:26:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{EB5C092C-8D46-1014-A129-F57E0145A7FD}] from master : 5
      05/13/16 10:56:26:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EB5C092C-8D46-1014-A129-F57E0145A7FD}] from master db : 7
      05/13/16 10:56:26:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] in master : 10
      05/13/16 10:56:26:995 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] from master db : 7
      05/13/16 10:56:26:995 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{F48E8FE8-8D40-1014-8129-D1C5ABFD087E}] from master : 5
      05/13/16 10:56:27:026 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{F48E8FE8-8D40-1014-8129-D1C5ABFD087E}] from master db : 7
      05/13/16 10:56:27:026 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{FDBEBEDE-D580-4B75-95F4-764849493A61}] from master : 5
      05/13/16 10:56:27:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{FDBEBEDE-D580-4B75-95F4-764849493A61}] from master db : 7
      05/13/16 10:56:27:058 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode
      05/13/16 10:56:27:058 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Finding suppressed LEIDs started
      05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | All keys in the GoCart subdomain retrieved sucesfully
      05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Looping through all keys in GoCart subdomain for suppressing
      05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Failed to fetch value for key GCGUID in subdomain GoCartDataUploadV2  with error : 8
      05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Failed to fetch value for key GCReplayID in subdomain GoCartDataUploadV2  with error : 8
      05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Finding suppressed LEIDs finished
      05/13/16 10:56:27:073 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Starting up SLCore 2.0 Release (build 2.0.1.360321).
      05/13/16 10:56:27:073 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Service construction took 0.2 ms and succeed.
      05/13/16 10:56:27:245 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Shutting down SLCore 2.0 Release (build 2.0.1.360321).
      05/13/16 10:56:27:245 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Service destruction took 0.4 ms and succeed.
      05/13/16 10:56:27:245 | [INFO] |  |  |  | AdobeGCIALWrapper |  |  | 5412 | Fetching Rules started
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | __OOBELIB_LOG_FILE__
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Dispatch table loaded from path: C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\dispatchtable.xml
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | (re)load Local Dispatch Table status-[0].
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Scope : [2]
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Setting scope to GM
      05/13/16 10:56:27:245 | [INFO] |  |  |  | AdobeGCIALWrapper |  |  | 5412 | AdobeIALClient 1.0 Release (build 1.0.6.3) initializing session...
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | EndPoint requested: [FetchRules]
      05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Length of the URL: [50]
      05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Returning from getEndpointAddr: [0]
      05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | EndPoint requested: [FetchRules]
      05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Length of the URL: [50]
      05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | URL found [https://genuine.adobe.com/server/services/rules/v1]
      05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library invoked = 2.6.0.81 ************05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4904 | Perform WF started05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4904 | Perform WF completed05/13/16 10:56:23:698 | [DEBUG] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Trying to acquire the semaphore05/13/16 10:56:23:698 | [DEBUG] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Semaphore acquired05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Threaded CFU Started05/13/16 10:56:23:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4536 | Get client install path Started05/13/16 10:56:23:714 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4536 | Get client install path Ended05/13/16 10:56:23:714 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Client sanitization started05/13/16 10:56:23:886 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Signature found05/13/16 10:56:23:886 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Found valid signature, checking if signed by Adobe or not05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Signature found05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCCodeSignWrapper |  |  | 4536 | Client app successfully signed05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCVersionWrapper |  |  | 4536 | Get version for file Started05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCVersionWrapper |  |  | 4536 | Get version for file Ended05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Client sanitization ended05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Threaded CFU Ended05/13/16 10:56:23:948 | [INFO] |  |  |  | AdobeGCUpdaterCFU |  |  | 4536 | Semaphore signalled05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library invoked = 2.6.0.81 ************05/13/16 10:56:24:698 | [DEBUG] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Trying to acquire the semaphore05/13/16 10:56:24:698 | [DEBUG] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Semaphore acquired05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Perform WF started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Get XML path Started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Create XML Started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding generic deails Started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding generic deails Ended05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding app deails Started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | App executable path C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe 05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | App Adobe code {CFB770D7-8D43-1014-922B-CC2715FADE3F}05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Adding app deails Ended05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Create XML Ended05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Storing XML Started05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Storing XML Ended05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterXMLWrapper |  |  | 4904 | Get XML path Ended05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Invoking GC client completed05/13/16 10:56:24:698 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | Get client install path Started05/13/16 10:56:24:714 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | Get client install path Ended05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Invoking GC client completed05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Perform WF completed05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdaterIC |  |  | 4904 | Semaphore signalled05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library End*******************05/13/16 10:56:24:792 | [INFO] |  |  |  | AdobeGCUpdater |  |  | 4904 | ***********AdobeGC Updater library End*******************05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | *********** Adobe GCClient Launched = 2.6.0.81 ************05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Initiating workflow05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Client request processing started05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientMain |  |  | 5412 | Mutex acquired, continue with the workflow05/13/16 10:56:25:042 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Initializing client workflow05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Trying to acquire the semaphore05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Semaphore acquired05/13/16 10:56:25:042 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode05/13/16 10:56:25:042 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the app executable for LEID : InDesign-CS6-Win-GM05/13/16 10:56:25:073 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the amt lib path for LEID : InDesign-CS6-Win-GM05/13/16 10:56:25:089 | [DEBUG] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Caching the adobe code for LEID : InDesign-CS6-Win-GM05/13/16 10:56:25:104 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode05/13/16 10:56:25:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] in master : 1005/13/16 10:56:25:245 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] from master db : 705/13/16 10:56:25:245 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] in master : 1005/13/16 10:56:25:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] from master db : 705/13/16 10:56:25:276 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] in master : 1005/13/16 10:56:25:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] from master db : 705/13/16 10:56:25:308 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] in master : 1005/13/16 10:56:25:339 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] from master db : 705/13/16 10:56:25:370 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] in master : 1005/13/16 10:56:25:401 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] from master db : 705/13/16 10:56:25:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] in master : 1005/13/16 10:56:25:433 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] from master db : 705/13/16 10:56:25:448 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] in master : 1005/13/16 10:56:25:464 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] from master db : 705/13/16 10:56:25:464 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{08D2E121-7F6A-43EB-97FD-629B44903403}] from master : 505/13/16 10:56:25:495 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{08D2E121-7F6A-43EB-97FD-629B44903403}] from master db : 705/13/16 10:56:25:495 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] in master : 1005/13/16 10:56:25:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{093DEFC4-542D-4D0A-8162-0592055515F4}] from master db : 705/13/16 10:56:25:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0AEC15F4-8EC3-4E2F-A5F0-6ABA39029D1B}] from master : 505/13/16 10:56:25:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0AEC15F4-8EC3-4E2F-A5F0-6ABA39029D1B}] from master db : 705/13/16 10:56:25:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0C4E7429-E920-4125-980E-029A87AE0A4D}] from master : 505/13/16 10:56:25:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0C4E7429-E920-4125-980E-029A87AE0A4D}] from master db : 705/13/16 10:56:25:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{0E0AA043-65AC-4A20-AAD6-9B4C7667309B}] from master : 505/13/16 10:56:25:604 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{0E0AA043-65AC-4A20-AAD6-9B4C7667309B}] from master db : 705/13/16 10:56:25:604 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{1EA52983-8EDD-1014-A956-E9729DA4AEEB}] from master : 505/13/16 10:56:25:620 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{1EA52983-8EDD-1014-A956-E9729DA4AEEB}] from master db : 705/13/16 10:56:25:636 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{24B187F6-7743-4EEC-8820-1B7374B6A4A2}] from master : 505/13/16 10:56:25:651 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{24B187F6-7743-4EEC-8820-1B7374B6A4A2}] from master db : 705/13/16 10:56:25:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{26F763C9-076F-473D-9A0E-4050C973737C}] from master : 505/13/16 10:56:25:683 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{26F763C9-076F-473D-9A0E-4050C973737C}] from master db : 705/13/16 10:56:25:683 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{2DAEE15D-8D47-1014-9FF6-ACA9093B5359}] from master : 505/13/16 10:56:25:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{2DAEE15D-8D47-1014-9FF6-ACA9093B5359}] from master db : 705/13/16 10:56:25:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] in master : 1005/13/16 10:56:25:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{311CDC89-AC18-4344-9EC9-0225328C73D3}] from master db : 705/13/16 10:56:25:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{354D20E6-A25F-4728-9DA6-C9003D8F2928}] from master : 505/13/16 10:56:25:761 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{354D20E6-A25F-4728-9DA6-C9003D8F2928}] from master db : 705/13/16 10:56:25:776 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{36682D68-3834-487E-BA49-DFA4AB0A2E32}] from master : 505/13/16 10:56:25:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{36682D68-3834-487E-BA49-DFA4AB0A2E32}] from master db : 705/13/16 10:56:25:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{373E3339-C141-4A99-A40A-77E28AFEF1B4}] from master : 505/13/16 10:56:25:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{373E3339-C141-4A99-A40A-77E28AFEF1B4}] from master db : 705/13/16 10:56:25:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{3871C312-24AC-4FCA-AD09-AD55E3237B98}] from master : 505/13/16 10:56:25:839 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{3871C312-24AC-4FCA-AD09-AD55E3237B98}] from master db : 705/13/16 10:56:25:839 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{39C798E1-96E1-1014-8C88-E90A74353141}] from master : 505/13/16 10:56:25:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{39C798E1-96E1-1014-8C88-E90A74353141}] from master db : 705/13/16 10:56:25:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{42C0738D-8D50-45B7-BC51-4BC609133E3A}] from master : 505/13/16 10:56:25:886 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{42C0738D-8D50-45B7-BC51-4BC609133E3A}] from master db : 705/13/16 10:56:25:886 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{4F38B549-96DF-1014-BBB1-C5F7191EB5AC}] from master : 505/13/16 10:56:25:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{4F38B549-96DF-1014-BBB1-C5F7191EB5AC}] from master db : 705/13/16 10:56:25:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{539AEF15-3A2B-4A31-A587-7E90F7D9C700}] from master : 505/13/16 10:56:25:917 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{539AEF15-3A2B-4A31-A587-7E90F7D9C700}] from master db : 705/13/16 10:56:25:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{544A2B1B-96E0-1014-B93E-8016F23F4105}] from master : 505/13/16 10:56:25:948 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{544A2B1B-96E0-1014-B93E-8016F23F4105}] from master db : 705/13/16 10:56:25:948 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{557F9FD3-EED8-43D7-AF29-0F19CA832728}] from master : 505/13/16 10:56:25:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{557F9FD3-EED8-43D7-AF29-0F19CA832728}] from master db : 705/13/16 10:56:25:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{5E0B469F-8D7F-1014-B892-BB4C1CDBC643}] from master : 505/13/16 10:56:25:979 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{5E0B469F-8D7F-1014-B892-BB4C1CDBC643}] from master db : 705/13/16 10:56:25:979 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{5EF99A9D-8D82-1014-9DEC-C24C3816749A}] from master : 505/13/16 10:56:26:011 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{5EF99A9D-8D82-1014-9DEC-C24C3816749A}] from master db : 705/13/16 10:56:26:011 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{60CCCE9D-8D78-1014-B66A-CEF4BA1DA4CD}] from master : 505/13/16 10:56:26:042 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{60CCCE9D-8D78-1014-B66A-CEF4BA1DA4CD}] from master db : 705/13/16 10:56:26:042 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] in master : 1005/13/16 10:56:26:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{784B5277-7B8A-4058-8F5D-A146F8BA5F7B}] from master db : 705/13/16 10:56:26:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{7E91BB17-16A1-42CE-9502-D6C98BE04920}] from master : 505/13/16 10:56:26:089 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{7E91BB17-16A1-42CE-9502-D6C98BE04920}] from master db : 705/13/16 10:56:26:089 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{8467887D-92F1-435C-B387-A7551B88EC70}] from master : 505/13/16 10:56:26:104 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{8467887D-92F1-435C-B387-A7551B88EC70}] from master db : 705/13/16 10:56:26:104 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{8E562D5B-8D73-1014-8DE0-BF91B9118C53}] from master : 505/13/16 10:56:26:136 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{8E562D5B-8D73-1014-8DE0-BF91B9118C53}] from master db : 705/13/16 10:56:26:136 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] from master : 505/13/16 10:56:26:151 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] from master db : 705/13/16 10:56:26:167 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] in master : 1005/13/16 10:56:26:183 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{94FEA41F-7345-429F-AA31-5C615F24CE29}] from master db : 705/13/16 10:56:26:183 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] from master : 505/13/16 10:56:26:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] from master db : 705/13/16 10:56:26:214 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9B78FAB0-AC6B-11E0-8EF3-00215AEA26C9}] from master : 505/13/16 10:56:26:229 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9B78FAB0-AC6B-11E0-8EF3-00215AEA26C9}] from master db : 705/13/16 10:56:26:229 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] from master : 505/13/16 10:56:26:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] from master db : 705/13/16 10:56:26:261 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9D2A060F-AC6B-11E0-8C00-00215AEA26C9}] from master : 505/13/16 10:56:26:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9D2A060F-AC6B-11E0-8C00-00215AEA26C9}] from master db : 705/13/16 10:56:26:292 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] from master : 505/13/16 10:56:26:323 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] from master db : 705/13/16 10:56:26:323 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{A0F72081-99FB-4FFA-AE1A-62B5A656CAC1}] from master : 505/13/16 10:56:26:354 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{A0F72081-99FB-4FFA-AE1A-62B5A656CAC1}] from master db : 705/13/16 10:56:26:354 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{AA9DC298-8D46-1014-853D-9FC0306FBFCE}] from master : 505/13/16 10:56:26:386 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{AA9DC298-8D46-1014-853D-9FC0306FBFCE}] from master db : 705/13/16 10:56:26:386 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B306E604-6439-49B9-B5D1-07503AF3E553}] from master : 505/13/16 10:56:26:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B306E604-6439-49B9-B5D1-07503AF3E553}] from master db : 705/13/16 10:56:26:417 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B4D27704-ABF7-4FB4-A6CE-E69925B2A682}] from master : 505/13/16 10:56:26:448 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B4D27704-ABF7-4FB4-A6CE-E69925B2A682}] from master db : 705/13/16 10:56:26:479 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] in master : 1005/13/16 10:56:26:511 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] from master db : 705/13/16 10:56:26:511 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B8CD128B-8D40-1014-B944-C86071713DAE}] from master : 505/13/16 10:56:26:526 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B8CD128B-8D40-1014-B944-C86071713DAE}] from master db : 705/13/16 10:56:26:542 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{B98E0DCB-1A75-4394-9813-3A114AA3891D}] from master : 505/13/16 10:56:26:558 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{B98E0DCB-1A75-4394-9813-3A114AA3891D}] from master db : 705/13/16 10:56:26:573 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{BF667E23-0186-41F1-ACAE-5786D4B34F56}] from master : 505/13/16 10:56:26:589 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{BF667E23-0186-41F1-ACAE-5786D4B34F56}] from master db : 705/13/16 10:56:26:589 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{C7B1C1B3-368D-4C32-A818-83F1554EB398}] from master : 505/13/16 10:56:26:620 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{C7B1C1B3-368D-4C32-A818-83F1554EB398}] from master db : 705/13/16 10:56:26:636 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{CEAB7536-8D73-1014-B405-F76E131B0743}] from master : 505/13/16 10:56:26:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{CEAB7536-8D73-1014-B405-F76E131B0743}] from master db : 705/13/16 10:56:26:667 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{CFA46C39-C539-4BE9-9364-495003C714AD}] from master : 505/13/16 10:56:26:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{CFA46C39-C539-4BE9-9364-495003C714AD}] from master db : 705/13/16 10:56:26:714 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] from master : 505/13/16 10:56:26:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] from master db : 705/13/16 10:56:26:745 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{D9BB636C-8D4E-1014-BDA3-9FE36B5694FE}] from master : 505/13/16 10:56:26:761 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{D9BB636C-8D4E-1014-BDA3-9FE36B5694FE}] from master db : 705/13/16 10:56:26:776 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DB39A1C8-8D51-1014-B2A3-BFB7AE176AF6}] from master : 505/13/16 10:56:26:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DB39A1C8-8D51-1014-B2A3-BFB7AE176AF6}] from master db : 705/13/16 10:56:26:792 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] from master : 505/13/16 10:56:26:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] from master db : 705/13/16 10:56:26:823 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] in master : 1005/13/16 10:56:26:854 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D}] from master db : 705/13/16 10:56:26:854 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{DE88AA40-6766-43D3-A755-8FC374B3D2C3}] from master : 505/13/16 10:56:26:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{DE88AA40-6766-43D3-A755-8FC374B3D2C3}] from master db : 705/13/16 10:56:26:870 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85}] from master : 505/13/16 10:56:26:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85}] from master db : 705/13/16 10:56:26:901 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] from master : 505/13/16 10:56:26:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] from master db : 705/13/16 10:56:26:933 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{EB5C092C-8D46-1014-A129-F57E0145A7FD}] from master : 505/13/16 10:56:26:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EB5C092C-8D46-1014-A129-F57E0145A7FD}] from master db : 705/13/16 10:56:26:964 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] in master : 1005/13/16 10:56:26:995 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] from master db : 705/13/16 10:56:26:995 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{F48E8FE8-8D40-1014-8129-D1C5ABFD087E}] from master : 505/13/16 10:56:27:026 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{F48E8FE8-8D40-1014-8129-D1C5ABFD087E}] from master db : 705/13/16 10:56:27:026 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | Failed to read value for key [LicensingCode] in hive [{FDBEBEDE-D580-4B75-95F4-764849493A61}] from master : 505/13/16 10:56:27:058 | [DEBUG] |  |  |  | PCDService |  |  | 5412 | No value for key [LicensingCode] in hive [{FDBEBEDE-D580-4B75-95F4-764849493A61}] from master db : 705/13/16 10:56:27:058 | [INFO] |  |  |  | PCDService |  |  | 5412 | PCD Service in non-threaded mode05/13/16 10:56:27:058 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Finding suppressed LEIDs started05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | All keys in the GoCart subdomain retrieved sucesfully05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Looping through all keys in GoCart subdomain for suppressing05/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Failed to fetch value for key GCGUID in subdomain GoCartDataUploadV2  with error : 805/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Failed to fetch value for key GCReplayID in subdomain GoCartDataUploadV2  with error : 805/13/16 10:56:27:073 | [INFO] |  |  |  | AdobeGCClientImpl |  |  | 5412 | Finding suppressed LEIDs finished05/13/16 10:56:27:073 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Starting up SLCore 2.0 Release (build 2.0.1.360321).05/13/16 10:56:27:073 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Service construction took 0.2 ms and succeed.05/13/16 10:56:27:245 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Shutting down SLCore 2.0 Release (build 2.0.1.360321).05/13/16 10:56:27:245 | [INFO] |  |  |  | SLCoreService |  |  | 5412 | Service destruction took 0.4 ms and succeed.05/13/16 10:56:27:245 | [INFO] |  |  |  | AdobeGCIALWrapper |  |  | 5412 | Fetching Rules started05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | __OOBELIB_LOG_FILE__05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Dispatch table loaded from path: C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\dispatchtable.xml 05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | (re)load Local Dispatch Table status-[0].05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Scope : [2]05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Setting scope to GM05/13/16 10:56:27:245 | [INFO] |  |  |  | AdobeGCIALWrapper |  |  | 5412 | AdobeIALClient 1.0 Release (build 1.0.6.3) initializing session...05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | EndPoint requested: [FetchRules]05/13/16 10:56:27:245 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Length of the URL: [50]05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Returning from getEndpointAddr: [0]05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | EndPoint requested: [FetchRules]05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Length of the URL: [50]05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | URL found [https://genuine.adobe.com/server/services/rules/v1]05/13/16 10:56:27:261 | [INFO] |  |  |  | DispatchClientLib |  |  | 5412 | Returning from getEndpointAddr: [0]
