1 Reply Latest reply on May 31, 2006 2:11 AM by BronwynL
    looping loadvars
    BronwynL
      Hi
      I'm writing a site in Flash where I want some of the copy to be dynamic, ie client can replace copy in text files that are loaded into the swf at runtime.
      I've been able to do it using the first bit of code below but since there are 15 external files I would like to do it in a loop. I found some code at http://proto.layer51.com/ (I hope it's OK to use) in the LoadVars section that looks like it should do the trick and I've tweaked to suit. (2nd chunk )
      Tracing summaries._loadedVars.toString() tells me that both files are in the _loadedVars array. Where it's falling over is in the onAllLoaded function. The loop never gets past 0 despite _loadedVars.length being 2.
      Can anyone see where my problem may be? Thanks in advance for any help you may be able to give.
      regards
