Windows 7, Acrobat Pro XI.
I've a number of users that are experiencing a recurring Registration Popup dialog while in Acrobat Pro XI despite selecting the never ask again option. Is this setting held in a file someplace which may not be getting replicated as part of the users' profile?
Hi barthw3679498,
Per guidelines for Acrobat deployment on citrix, after installing Acrobat on master image provision it via APTEE tool .
Following are the commands for provisioning
1. "adobe_prtk --tool=VolumeSerialize --generate --serial=
<serialnum> [--leid=<LEID>] [--regsuppress=ss] [--eulasuppress]
[--locales=list of locales in xx_XX format or ALL>] [--provfile=<Absolute path to prov.xml>]"
2. "adobe_prtk --tool=VolumeSerialize [--provfile=<Absolute path to prov.xml>] [--stream]"
After that a sin
...Copy link to clipboard
HI Barth,
A few questions:
These are on Citrix VDI desktops – so yes, they have a common base image.
b-
Update – so it turns out I was using the tool correctly. Though it would simply respond back that some “unknown” error had occurred.
So, after engaging Adobe tech support through a variety of websites, it turns out there was a problem with my key, which would have never allowed the utility to work.
I’m not sure if there’s a telephone shortcut to get to the tech support, but I ended up wading through a bunch of web-based support before finally getting someone at Adobe to actually schedule a tech support call.
Thanks everyone for your assistance.
-B.
Hi barthw3679498,
Can you please share the exact steps how you deployed Acrobat Pro XI on your base image.
Also if all users are facing this issue or only a subset of users are getting this.
Regards
Ravinder
Simply installed it using the installer and gave it the key.
-b
Hi barthw3679498,
After that a single launch of Acrobat is required on master image before cloning it to clients.
Regards
Ravinder
Thank you for the reply, but we don’t have Creative Cloud installed, this is strictly Acrobat Pro XI.
-b
The answer doesn't have anything to do with CC. Try following the instructions in the documentation provided above. Use the APTEE tool.
Ben
Oh gotcha. So how do I know if this this actually successfully accepted the input switches ?
-b
Well if it doesn't throw an error and the popup doesn't appear after launching a test install, then success is yours.
I'm not sure if you'll see a "Success" msg.
Ben
Hi barthw3679498,
Commands shared above returns '0' return code on execution indicating success.
Regards
Ravinder
