0 Replies Latest reply on May 17, 2016 8:35 AM by thouck@fnbokla.com
    Digital signature, no changes other than additional signatures, print everything
    thouck@fnbokla.com
      Acrobat XI Pro used for creating the form.
      Acrobat XI Standard used for end user to open the form.
      I have a form with three signature fields.  After the first or even the second signature, I want all fields except the second or third signature to lock down to not be editable.  After the third person signs I need to be able to print the entire document with all the signatures.
      Changing the Document and Markups or Annotations in the print dialog box doesn't help when I set the signature field to make everything read only.  If I don't set the signature to read only then the form is still editable but all the signatures will print regardless of what print dialog preferences are set to.
