3 Replies Latest reply on May 25, 2016 2:17 PM by kerrishotts
    Icon Default
    TheHaltt
      English
      Good morning , my application without problems , however WHEN USE Command PhoneGap build remote android and sends IT FOR Adobe website PhoneGap Build Process AFTER EVEN puts the Standard icon . I wonder if someone could solve this problem UO guide me What Am I Doing Wrong .
      Thanks in advance.
      Português
      Bom dia, meu aplicativo sem problemas, porem quando uso o comando phonegap remote build android e ele manda para o site Adobe PhoneGap Build o mesmo depois do processo coloca o ícone padrão. Gostaria de saber se alguem conseguiu resolver esse problema ou me orientar o que estou fazendo de errado.
      Desde já Obrigado.
        • 1. Re: Icon Default
          kerrishotts Adobe Employee
          I think I understand what you're asking, but I'm not 100% sure. Is the issue this: app that you download from PGBuild has the default icon instead of the icon you created?
          If so, can you share your config.xml file and the path to your icons?
          • 2. Re: Icon Default
            TheHaltt Level 1
            Below my config.xml , thanks for the help.
            <author email="wandersonteixeira@live.com" href="http://wandersonteixeira.com.br">Wanderson Teixeira ME</author>
                <content src="index.html" />
                <preference name="DisallowOverscroll" value="true" />
                <preference name="android-minSdkVersion" value="14" />
                <preference name="SplashScreen" value="screen" />
                <preference name="SplashScreenDelay" value="5000" />
                <preference name="windows-arch" value="anycpu" />
                <preference name="windows-identity-name" value="28615Haltt.ComShalom" />
                <plugin name="cordova-plugin-battery-status" source="npm" spec="~1.1.1" />
                <plugin name="cordova-plugin-camera" source="npm" spec="~2.1.1" />
                <plugin name="cordova-plugin-media-capture" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-console" source="npm" spec="~1.0.2" />
                <plugin name="cordova-plugin-contacts" source="npm" spec="~2.0.1" />
                <plugin name="cordova-plugin-device" source="npm" spec="~1.1.1" />
                <plugin name="cordova-plugin-device-motion" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-device-orientation" source="npm" spec="~1.0.2" />
                <plugin name="cordova-plugin-dialogs" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-file" source="npm" spec="~4.1.1" />
                <plugin name="cordova-plugin-file-transfer" source="npm" spec="~1.5.0" />
                <plugin name="cordova-plugin-geolocation" source="npm" spec="~2.1.0" />
                <plugin name="cordova-plugin-globalization" source="npm" spec="~1.0.3" />
                <plugin name="cordova-plugin-inappbrowser" source="npm" spec="~1.3.0" />
                <plugin name="cordova-plugin-media" source="npm" spec="~2.2.0" />
                <plugin name="cordova-plugin-network-information" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-splashscreen" source="npm" spec="~3.2.1" />
                <plugin name="cordova-plugin-statusbar" source="npm" spec="~2.1.2" />
                <plugin name="cordova-plugin-vibration" source="npm" spec="~2.1.0" />
                <plugin name="cordova-plugin-whitelist" source="npm" spec="~1.2.1" />
                <icon src="www/res/icon.png" />
                <platform name="android">
                    <icon density="ldpi" src="www/res/icon/android/drawable-ldpi-icon.png" />
                    <icon density="mdpi" src="www/res/icon/android/drawable-mdpi-icon.png" />
                    <icon density="hdpi" src="www/res/icon/android/drawable-hdpi-icon.png" />
                    <icon density="xhdpi" src="www/res/icon/android/drawable-xhdpi-icon.png" />
                    <icon density="xxhdpi" src="www/res/icon/android/drawable-xxhdpi-icon.png" />
                    <icon density="xxxhdpi" src="www/res/icon/android/drawable-xxxhdpi-icon.png" />
                    <splash density="land-ldpi" src="www/res/screen/android/drawable-land-ldpi-screen.png" />
                    <splash density="land-mdpi" src="www/res/screen/android/drawable-land-mdpi-screen.png" />
                    <splash density="land-hdpi" src="www/res/screen/android/drawable-land-hdpi-screen.png" />
                    <splash density="land-xhdpi" src="www/res/screen/android/drawable-land-xhdpi-screen.png" />
                    <splash density="land-xxhdpi" src="www/res/screen/android/drawable-land-xxhdpi-screen.png" />
                    <splash density="land-xxxhdpi" src="www/res/screen/android/drawable-land-xxxhdpi-screen.png" />
                    <splash density="port-ldpi" src="www/res/screen/android/drawable-port-ldpi-screen.png" />
                    <splash density="port-mdpi" src="www/res/screen/android/drawable-port-mdpi-screen.png" />
                    <splash density="port-hdpi" src="www/res/screen/android/drawable-port-hdpi-screen.png" />
                    <splash density="port-xhdpi" src="www/res/screen/android/drawable-port-xhdpi-screen.png" />
                    <splash density="port-xxhdpi" src="www/res/screen/android/drawable-port-xxhdpi-screen.png" />
                    <splash density="port-xxxhdpi" src="www/res/screen/android/drawable-port-xxxhdpi-screen.png" />
                </platform>
                <platform name="ios">
                    <icon height="57" platform="ios" src="www/res/icon/ios/icon.png" width="57" />
                    <icon height="114" platform="ios" src="www/res/icon/ios/icon@2x.png" width="114" />
                    <icon height="40" platform="ios" src="www/res/icon/ios/icon-40.png" width="40" />
                    <icon height="80" platform="ios" src="www/res/icon/ios/icon-40@2x.png" width="80" />
                    <icon height="50" platform="ios" src="www/res/icon/ios/icon-50.png" width="50" />
                    <icon height="100" platform="ios" src="www/res/icon/ios/icon-50@2x.png" width="100" />
                    <icon height="60" platform="ios" src="www/res/icon/ios/icon-60.png" width="60" />
                    <icon height="120" platform="ios" src="www/res/icon/ios/icon-60@2x.png" width="120" />
                    <icon height="180" platform="ios" src="www/res/icon/ios/icon-60@3x.png" width="180" />
                    <icon height="72" platform="ios" src="www/res/icon/ios/icon-72.png" width="72" />
                    <icon height="144" platform="ios" src="www/res/icon/ios/icon-72@2x.png" width="144" />
                    <icon height="76" platform="ios" src="www/res/icon/ios/icon-76.png" width="76" />
                    <icon height="152" platform="ios" src="www/res/icon/ios/icon-76@2x.png" width="152" />
                    <icon height="29" platform="ios" src="www/res/icon/ios/icon-small.png" width="29" />
                    <icon height="58" platform="ios" src="www/res/icon/ios/icon-small@2x.png" width="58" />
                    <icon height="87" platform="ios" src="www/res/icon/ios/icon-small@3x.png" width="87" />
                    <splash height="1136" platform="ios" src="www/res/screen/ios/Default-568h@2x~iphone.png" width="640" />
                    <splash height="1334" platform="ios" src="www/res/screen/ios/Default-667h.png" width="750" />
                    <splash height="2208" platform="ios" src="www/res/screen/ios/Default-736h.png" width="1242" />
                    <splash height="1242" platform="ios" src="www/res/screen/ios/Default-Landscape-736h.png" width="2208" />
                    <splash height="1536" platform="ios" src="www/res/screen/ios/Default-Landscape@2x~ipad.png" width="2048" />
                    <splash height="768" platform="ios" src="www/res/screen/ios/Default-Landscape~ipad.png" width="1024" />
                    <splash height="2048" platform="ios" src="www/res/screen/ios/Default-Portrait@2x~ipad.png" width="1536" />
                    <splash height="1024" platform="ios" src="www/res/screen/ios/Default-Portrait~ipad.png" width="768" />
                    <splash height="960" platform="ios" src="www/res/screen/ios/Default@2x~iphone.png" width="640" />
                    <splash height="480" platform="ios" src="www/res/screen/ios/Default~iphone.png" width="320" />
                </platform>
                <platform name="wp8">
                    <icon height="99" platform="wp8" src="www/res/icon/wp8/ApplicationIcon.png" width="99" />
                    <icon height="159" platform="wp8" src="www/res/icon/wp8/Background.png" width="159" />
                    <splash height="1280" platform="wp8" src="www/res/screen/wp8/screen-portrait.jpg" width="768" />
                </platform>
                <platform name="windows">
                    <icon height="150" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-100.png" width="150" />
                    <icon height="30" platform="windows" src="www/res/icon/windows/Square30x30Logo.scale-100.png" width="30" />
                    <icon height="50" platform="windows" src="www/res/icon/windows/StoreLogo.scale-100.png" width="50" />
                    <splash height="300" platform="windows" src="www/res/screen/windows/SplashScreen.scale-100.png" width="620" />
                    <icon height="120" platform="windows" src="www/res/icon/windows/StoreLogo.scale-240.png" width="120" />
                    <icon height="44" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-100.png" width="44" />
                    <icon height="106" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-240.png" width="106" />
                    <icon height="70" platform="windows" src="www/res/icon/windows/Square70x70Logo.scale-100.png" width="70" />
                    <icon height="71" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-100.png" width="71" />
                    <icon height="170" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-240.png" width="170" />
                    <icon height="360" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-240.png" width="360" />
                    <icon height="310" platform="windows" src="www/res/icon/windows/Square310x310Logo.scale-100.png" width="310" />
                    <icon height="150" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-100.png" width="310" />
                    <icon height="360" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-240.png" width="744" />
                    <splash height="1920" platform="windows" src="www/res/screen/windows/SplashScreenPhone.scale-240.png" width="1152" />
                </platform>
                <access origin="*" />
                <allow-intent href="http://*/*" />
                <allow-intent href="https://*/*" />
                <allow-intent href="tel:*" />
                <allow-intent href="sms:*" />
                <allow-intent href="mailto:*" />
                <allow-intent href="geo:*" />
                    <allow-intent href="market:*" />
                </platform>
                    <allow-intent href="itms:*" />
                    <allow-intent href="itms-apps:*" />
                </platform>
                <engine name="wp8" spec="~3.8.2" />
                <engine name="windows" spec="~4.3.2" />
                <engine name="android" spec="~5.1.1" />
            </widget>
            Below my config.xml
            • 3. Re: Icon Default
              Could you please share a screenshot of your folder structure?
