2 Replies Latest reply on Nov 26, 2018 1:36 PM by subieguy2
    Batch Downsaving Illustrator CC files to CS6?
    gdsolsu Level 1
      Hello,
      I am trying to downsave over 100 illustrator files to CS6 Legacy with linked files and I can't seem to find an option for that in the batch or actions options. It would work with actions, except when you record a save, the most illustrator records is where you saved to, not if you saved CS6, CS5, etc.
      Anyone else run into this issue?
      Thanks.
        • 1. Re: Batch Downsaving Illustrator CC files to CS6?
          ohmnath Adobe Employee
          I believe that can be done though scripting. I am moving this thread to Illustrator Scripting for you and hope we get a helpful response there.
          Regards,
          Om
          • 2. Re: Batch Downsaving Illustrator CC files to CS6?
            subieguy2 Level 3
            You could try this....
            https://gist.github.com/joonaspaakko/df2f9e31bdb365a6e5df
            // Illustrator convert to legacy.jsx
            // https://gist.github.com/joonaspaakko/df2f9e31bdb365a6e5df
            // Finds all .ai files from the input folder + its subfolders and converts them to the version given below in a variable called "targetVersion"
            // Tested in Illustrator cc 2014 (Mac)
            // Didn't bother to do a speed test with my macbook air...
            #target illustrator
              // If set to false, a new file will be written next to the original file.
              // The new file will have (legacyFile) in the name.
              // Files with (legacyFile) in the file name are always ignored.
            var overwrite = true, // boolean
              // Accepted values:
              // 8, 9, 10, 11 (cs), 12 (cs2), 13 (cs3), 14 (cs4), 15 (cs5), 16 (cs6), 17 (cc)
              targetVersion = 13;
            if ( app.documents.length > 0 ) {
              alert("ERROR: \n Close all documents before running this script." );
            // Run the script
            else {
              var files,
              folder = Folder.selectDialog("Input folder...");
              // If folder variable return null, user most likely canceled the dialog or
              // the input folder and it subfolders don't contain any .ai files.
               if ( folder != null ) {
               // returns an array of file paths in the selected folder.
              files = GetFiles( folder );
               // This is where things actually start happening...
              process( files );
            function process( files ) {
               // Loop through the list of .ai files:
               // Open > Save > Close > LOOP
               for ( i = 0; i < files.length; i++ ) {
               // Current file
              var file = files[i]
               // Open
              app.open( file );
               // If overwrite is false, create a new file, otherwise use "file" variable;
              file = !overwrite ? new File( file.toString().replace(".ai", " (legacyFile).ai") ) : file;
               // Save
              app.activeDocument.saveAs( file, SaveOptions_ai() )
               // Close
              app.activeDocument.close( SaveOptions.DONOTSAVECHANGES );
               // For better of for worse...
              alert( "Script is done." );
            function SaveOptions_ai() {
              var saveOptions = new IllustratorSaveOptions();
              saveOptions.compatibility = Compatibility[ "ILLUSTRATOR" + targetVersion ];
              saveOptions.flattenOutput = OutputFlattening.PRESERVEAPPEARANCE;
              saveOptions.compressed = true; // Version 10 or later
              saveOptions.pdfCompatible = true; // Version 10 or later
              saveOptions.embedICCProfile = true; // Version 9 or later
              saveOptions.embedLinkedFiles = false; // Version 7 or later
               return saveOptions
            function GetFiles( folder ) {
              var i, item,
               // Array to store the files in...
              files = [],
               // Get files...
              items = folder.getFiles();
               // Loop through all files in the given folder
               for ( i = 0; i < items.length; i++ ) {
              item = items[i];
               // Find .ai files
              var fileformat = item.name.match(/\.ai$/i),
              legacyFile = item.name.indexOf("(legacyFile)") > 0;
               // If item is a folder, check the folder for files.
               if ( item instanceof Folder ) {
               // Combine existing array with files found in the folder
              files = files.concat( GetFiles( item ) );
               // If the item is a file, push it to the array.
               else if ( item instanceof File && fileformat && !legacyFile ) {
               // Push files to the array
              files.push( item );
               return files;
