Colleen,
The moment you start using audio with Breeze, it'll create a
.ppc file which won't be of particular use when trying to migrate
audio from one presentation to another...however...
IF you've published a preso, a series of mp3 files will be
created for the content. Depending on whether you have published
locally or via the Breeze server, the audio files will be available
for you to use in other presos. To be honest, I don't have a Breeze
server to publish to, but the resulting .zip file that is available
from the Breeze server should result in the same output as content
that is published locally. Bottom line: you need to look for a Data
folder from the published content, and in it should be all the mp3
files used for the presentation.
From there, it should be a simple matter of importing the mp3
file to the appropriate slide using the Import Audio command from
the Breeze menu.
Rob
