3 Replies Latest reply on Nov 9, 2016 3:12 AM by maxoncomputergmbh
    Script Error on startup
      Getting a strange error on startup. I have completely uninstalled cleaned and reinstalled creative cloud but still getting it.
      Running After Effects CC 2015 on Yosemite.
      Any help would be appreciated
      Screenshot below.
        • 1. Re: Script Error on startup
          It could be a permissions issue. Some tiny little folder somewhere buried in your folder structure isn't set right.
          Alternatively, it could be some third-party script messing with things. You haven't installed any scripts or plugins yet, have you?
          • 2. Re: Script Error on startup
            UQg Level 4
            I can't be 100% sure since i havent reinstalled After Effects for a while, but i think that unistalling After Effects will only remove the AE package, that is, only things that have been installed by Adobe. Meaning: third party scripts are not removed.
            So, even if you have uninistalled/reinstalled, still check that you don't have a third party script in the Scripts/Startup folder.
            The list of files in that folder is normally :
            • 1_startup.jsx
            • About the Startup folder.txt
            • commandLineRenderer.jsx
            Anything else should be third party.
            • 3. Re: Script Error on startup
              I'm running into the same issue with a fresh AE install (no AE was ever installed before). Are there any solutions to this issue?
              The script / startup folder only has the three files mentioned above.
