Please I have a webapp list. I want to show or hide the previous and next pagination url based on the number of pages left and user clicks the pagination url:
Please this is my code:
<div class="pagination">
<div class="paginationtextblock"><a href="{{testimonialWinners.pagination.previousPageUrl}}">Previous</a></div>
<div class="paginationtextblock">Page {{testimonialWinners.pagination.currentPage}}</div>
<div class="paginationtextblock" style="hidden"><a href="{{testimonialWinners.pagination.nextPageUrl}}">Next</a></div>
</div>
</div>
Thanks in anticipation
Hi Stephen, thanks once again for the contribution. But after looking at your implementation code and what is returned through json. I carved my own solution, which I found straight found and doesn't require so much assign. See it below:
{% if collectionname.pagination.previousPageUrl != null -%}
<div class="paginationtextblock"><a href="{{collectionname.pagination.PreviousPageUrl}}">Previous</a></div>
{% endif -%}
Tip: Have a look at the url as you paginate.
Hi Liam this is what I got from the url as I paginate: ?PageID=17992214&A=WebApp&CCID=29948&Page=4&Items=10
Look at the pagination URLs we did on this website (still in development)
Contributor Picks
One method we chose to go with was simply placing "?A=WebApp&Page=2" at the end of the URL like so: /contributor-picks?A=WebApp&Page=2
Then with the following code:
{% assign pageURL = globals.get.id -%}<!--- get the current page ID -->
{% assign previousPageUrl = "" -%}
{% assign nextPageUrl = 2 -%}
{% if globals.get.Page > 1 -%}<!-- if &Page exists and is greater than 1, then we know we are on a pagination page. -->
{% assign previousPageUrl = globals.get.Page | minus: 1 -%}
{% assign nextPageUrl = globals.get.Page | plus: 1 -%}
{% endif -%}
Then once you have your variables, you can do things like:
{% if pagination.previousPageUrl != null -%}
<li><a href="{{ pageURL }}?A=WebApp&Page={{ previousPageUrl }}"><i class="material-icons"></i></a></li>
{% endif -%}
-- AND --
{% if pagination.nextPageUrl != null -%}
<li><a href="{{ pageURL }}?A=WebApp&Page={{ nextPageUrl }}"><i class="material-icons"></i></a></li>
{% endif -%}
This is one method we did. There are more. Hope this gives inspiration to find a solution for your situation.
Thanks Stephen, I will test and let you know.
{% endif -%}
<div class="paginationtextblock">Page {{collectionname.pagination.currentPage}} of {{collectionname.pagination.numberOfPages}}</div>
{% if collectionname.pagination.nextPageUrl != null -%}
<div class="paginationtextblock"><a href="{{collectionname.pagination.nextPageUrl}}">Next</a></div>
{% endif -%}
</div>
See it in action here: Schools in the Astymin schools support program
I think the last BC update presented more options for pagination which allows us to do more based on the json tags available. Thanks once again for inspiring me.
