I have some training that was saved as .swf files and the original PowerPoint files are no longer available. I need to be able to get the .swf file back into a PowerPoint editable file. Can Presenter do that? I have been able to import the .swf into a presentation but not break it back down into slides, only play like an embedded video. I have several .swf files that are over 50 slides each and do not want to have to recreate each presentation.
Thanks!
Unfortunately not. The conversion from PPT to SWF is one way.
If the Source files were uploaded to Connect with the published presentation then you should be able to pull down the source PPT. Other than that, I think you may be stuck recreating the slides unless you run across a back up of the originals.
