8 Replies Latest reply on May 24, 2016 11:54 AM by JJMack
    Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
    azotez Level 1
      Hi there,
      I'm trying to batch the following script on a remote CDN containing more than 9000 subfolders:
      // get a reference to the current (active) document and store it in a variable named "doc"
      doc = app.activeDocument;
      if(doc.name.indexOf('ws')>0){
          var filename = doc.name.replace(".jpg", "");
        var origName = filename+'_o.jpg';
        var origFile = File(doc.path+'/'+origName);
        if(!origFile.exists) {
        // change the color mode to RGB.  Important for resizing GIFs with indexed colors, to get better results
        doc.changeMode(ChangeMode.RGB);
        var jpeg_options = new JPEGSaveOptions();
        jpeg_options.embedColorProfile = 1;
        jpeg_options.formatOptions = FormatOptions.STANDARDBASELINE;
        jpeg_options.matte = MatteType.WHITE;
        jpeg_options.quality = 11;
        doc.saveAs(File(doc.path+'/'+origName), jpeg_options, 1);
        // these are our values for the END RESULT width and height (in pixels) of our image
        var fWidth = 3000;
        var fHeight = 3000;
        // our web export options
        var options = new ExportOptionsSaveForWeb();
        options.format = SaveDocumentType.JPEG;
        options.quality = 90;
        options.optimized = true;
        // do the resizing.  if height > width (portrait-mode) resize based on height.  otherwise, resize based on width
        if (doc.height > fHeight || doc.width > fWidth){
        if (doc.height > doc.width) {
        doc.resizeImage(null,UnitValue(fHeight,"px"),null,ResampleMethod.BILINEAR);
        else {
        doc.resizeImage(UnitValue(fWidth,"px"),null,null,ResampleMethod.BILINEAR);
        doc.exportDocument(File(doc.path+'/'+doc.name),ExportType.SAVEFORWEB,options);
      app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      The script works perfectly if I test it locally with a brunch of folders.
      When I create a droplet or when I run a batch into the CDN (mounted a ) I have the following problems:
      1. Photoshop freezes for more than an hour before starting the files cycle.
        What can I do to avoid this idle?
      2. Photoshop tries to open Thumbs.db files and it logs me this error for every folder:
        Error: Could not complete your request because Photoshop cannot recognize the file extension. (-25600)
        Is there a way to make a batch process try to open just the readable files?
      3. For all the images (both the ones that I would like to be resized and the ones that I just need to skip) it returns me the following error:
        Error: Could not complete your request because of a program error. (-1)
        That in the PSErrorLog.txt turns out to be:
        2016:05:20 16:01:53 : ..\..\sources\OWLPanelManager.cpp : 3936 : REQUIRE failed
        No image is resized or saved in this case..
        What does it means? How can I solve this error?
      Anyone could help?
      Thanks a lot!
        • 1. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
          Akash Sharma Adobe Employee
          Moving to  Photoshop Scripting.
          • 3. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
            azotez Level 1
            Thanks JJMack for the Google link..
            Can you exactly tell me where - clicking on your link - I can find a solution to one of the 3 problems I mentioned?
            I checked Google before writing this post and after you posted your link, but still nothing helpful there...
            Ah.. Generator is turned off and I have re-installed everything from my regular CC account before posting..
            Anyway thanks...
            • 4. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
              Where what? All I could find were those few search results. I have no idea what you are doing or what OWLPanelManager.cpp is part of.  I could not even find that out.  What are you using?
              • 5. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
                azotez Level 1
                The Photoshop error file log (PSErrorLog.txt) says that I'm missing a OWLPanelManager.cpp file in my computer (Licensed Windows 7 64bit and latest licensed Photoshop CC update).
                I don't know why my Photoshop script is looking for that file.. But I have no "OWLPanelManager.cpp" in my hard drive..
                And it's not the only problem I have..
                I hoped to find an Adobe Programmer here that could help me but it seems that this is just a users forums and there is no way to contact Adobe for the support..
                Thank you anyway!
                • 6. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
                  I use Windows 10 and see a PSErrorLog.txt fo CS6, CC, CC 2014, and CC 2015.  None contain a message about OWLPanelManager.cpp and no file by that name exists on my system.  Do you install any Photoshop extensions and third party plug-in.  Please post you cc 2015 menu Help>System Info...
                  • 7. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
                    azotez Level 1
                    Hi JJmack,
                    No, i did not install any external plugin and as you can see from my script I'm not doing anything special..
                    Here you are my System Info:
                    Adobe Photoshop Version: 2015.1.2 20160113.r.355 2016/01/13:23:59:59 CL 1059143  x64
                    Operating System: Windows 7 64-bit
                    Version: 7 SP1
                    System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                    Physical processor count: 4
                    Logical processor count: 8
                    Processor speed: 3491 MHz
                    Built-in memory: 8100 MB
                    Free memory: 1647 MB
                    Memory available to Photoshop: 7036 MB
                    Memory used by Photoshop: 70 %
                    Modifier Palette: Disabled.
                    Design Space: Disabled.
                    Artboards: Enabled.
                    3D Multitone Printing: Disabled.
                    Highbeam: Enabled.
                    Image tile size: 0K
                    Image cache levels: 0
                    Font Preview: Medium
                    TextComposer: Latin
                    Display: 1
                    Display Bounds: top=0, left=0, bottom=1200, right=1920
                    Display: 2
                    Display Bounds: top=0, left=1920, bottom=1080, right=3840
                    OpenGL Drawing: Disabled.
                    OpenGL Allow Old GPUs: Not Detected.
                    OpenGL Drawing Mode: Advanced
                    OpenGL Allow Normal Mode: True.
                    OpenGL Allow Advanced Mode: True.
                    AIFCoreInitialized=1
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=1
                    glgpu[0].GLVersion="3.0"
                    glgpu[0].IsIntegratedGLGPU=0
                    glgpu[0].GLMemoryMB=4096
                    glgpu[0].GLName="NVIDIA Quadro K2200"
                    glgpu[0].GLVendor="NVIDIA Corporation"
                    glgpu[0].GLVendorID=4318
                    glgpu[0].GLDriverVersion="9.18.13.4752"
                    glgpu[0].GLRectTextureSize=16384
                    glgpu[0].GLRenderer="Quadro K2200/PCIe/SSE2"
                    glgpu[0].GLRendererID=5050
                    glgpu[0].HasGLNPOTSupport=1
                    glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                    glgpu[0].GLDriverDate="20150205000000.000000-000"
                    glgpu[0].CanCompileProgramGLSL=1
                    glgpu[0].GLFrameBufferOK=1
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                    clgpu[0].CLPlatformVersion="1.1"
                    clgpu[0].CLDeviceVersion="1.1 CUDA"
                    clgpu[0].IsIntegratedCLGPU=0
                    clgpu[0].CLMemoryMB=4096
                    clgpu[0].CLName="Quadro K2200"
                    clgpu[0].CLVendor="NVIDIA Corporation"
                    clgpu[0].CLVendorID=4318
                    clgpu[0].CLDriverVersion="347.52"
                    clgpu[0].CUDASupported=1
                    clgpu[0].CUDAVersion="7.0.23"
                    clgpu[0].CLBandwidth=6.201e+010
                    clgpu[0].CLCompute=401.217
                    License Type: Subscription
                    Serial number: 94070255320848785530
                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\
                    Temporary file path: C:\Users\trevisan\AppData\Local\Temp\
                    Photoshop scratch has async I/O enabled
                    Scratch volume(s):
                      Startup, 226,5G, 22,1G free
                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\Plug-Ins\
                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Plug-ins\
                    Installed components:
                       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                       ACE.dll   ACE 2015/09/09-18:52:48   79.567158   79.567158
                       AdbePM.dll   PatchMatch 0000/00/00-00:00:00   1.   1.
                       AdobeLinguistic.dll   Adobe Linguisitc Library   9.0.0
                       AdobeOwl.dll   Adobe Owl   5.2.9
                       AdobePDFL.dll   PDFL 2015/09/12-01:10:45   79.156620   79.156620
                       AdobePIP.dll   Adobe Product Improvement Program   7.3.1.70
                       AdobeSVGAGM.dll   AdobeSVGAGM   79.566705   79.566705
                       AdobeXMP.dll   Adobe XMP Core 2015/09/10-01:10:20   79.158325   79.158325
                       AdobeXMPFiles.dll   Adobe XMP Files 2015/09/10-01:10:20   79.158325   79.158325
                       AdobeXMPScript.dll   Adobe XMP Script 2015/09/10-01:10:20   79.158325   79.158325
                       adobe_caps.dll   Adobe CAPS   9,0,0,28
                       AGM.dll   AGM 2015/09/09-18:52:48   79.567158   79.567158
                       ahclient.dll    AdobeHelp Dynamic Link Library   2.0.0.2
                       AIDE.dll   AIDE 2015/10/15-11:58:31   79.568000   79.568000
                       amtlib.dll   AMTLib (64 Bit)   9.0.0.89BuildVersion: 9.0; BuildDate: Tue Aug 25 2015 7:30:38)   1.000000
                       ARE.dll   ARE 2015/09/09-18:52:48   79.567158   79.567158
                       AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                       AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                       Bib.dll   BIB 2015/09/09-18:52:48   79.567158   79.567158
                       BIBUtils.dll   BIBUtils 2015/09/09-18:52:48   79.567158   79.567158
                       boost_date_time.dll   photoshopdva   8.0.0
                       boost_signals.dll   photoshopdva   8.0.0
                       boost_system.dll   photoshopdva   8.0.0
                       boost_threads.dll   photoshopdva   8.0.0
                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                       CIT.dll   Adobe CIT   2.3.7.33275   2.3.7.33275
                       CITThreading.dll   Adobe CITThreading   2.3.7.33275   2.3.7.33275
                       CoolType.dll   CoolType 2015/09/09-18:52:48   79.567158   79.567158
                       dnssd.dll   Bonjour   3,0,0,2
                       dvaaudiodevice.dll   photoshopdva   8.0.0
                       dvacore.dll   photoshopdva   8.0.0
                       dvamarshal.dll   photoshopdva   8.0.0
                       dvamediatypes.dll   photoshopdva   8.0.0
                       dvametadata.dll   photoshopdva   8.0.0
                       dvametadataapi.dll   photoshopdva   8.0.0
                       dvametadataui.dll   photoshopdva   8.0.0
                       dvaplayer.dll   photoshopdva   8.0.0
                       dvatransport.dll   photoshopdva   8.0.0
                       dvaui.dll   photoshopdva   8.0.0
                       dvaunittesting.dll   photoshopdva   8.0.0
                       dynamiclink.dll   photoshopdva   8.0.0
                       ExtendScript.dll   ExtendScript 2015/04/17-16:55:22   80.1017022   80.1017022
                       icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       igestep30.dll   IGES Reader   9.3.0.113
                       imslib.dll   IMSLib DLL   9.0.1.14
                       JP2KLib.dll   JP2KLib 2015/08/14-01:13:58   79.258941   79.258941
                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                       libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                       LogSession.dll   LogSession   7.3.1.70
                       manta.dll   Manta   1.   1.
                       mediacoreif.dll   photoshopdva   8.0.0
                       MPS.dll   MPS 2015/08/14-01:13:58   79.566687   79.566687
                       pdfsettings.dll   Adobe PDFSettings   1.04
                       Photoshop.dll   Adobe Photoshop CC 2015   16.1.2
                       Plugin.dll   Adobe Photoshop CC 2015   16.1.2
                       PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   6.1.0
                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   6.1.0.164
                       PSArt.dll   Adobe Photoshop CC 2015   16.1.2
                       PSViews.dll   Adobe Photoshop CC 2015   16.1.2
                       SCCore.dll   ScCore 2015/04/17-16:55:22   80.1017022   80.1017022
                       SVGRE.dll   SVGRE   79.566690   79.566690
                       svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                       tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 3, 2015, 0408
                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 3, 2015, 0408
                       TfFontMgr.dll   FontMgr   9.3.0.113
                       TfKernel.dll   Kernel   9.3.0.113
                       TFKGEOM.dll   Kernel Geom   9.3.0.113
                       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                       updaternotifications.dll   Adobe Updater Notifications Library   9.0.0.15 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   9.0.0.15
                       VulcanControl.dll   Vulcan Application Control Library   5.2.0.35
                       VulcanMessage5.dll   Vulcan Message Library   5.2.0.35
                       WRServices.dll   WRServices Fri Jul 31 2015 07:50:10   Build 0.21834   0.21834
                       wu3d.dll   U3D Writer   9.3.0.113
                    Required plug-ins:
                       3D Studio 16.1.2 (2015.1.2 x001 x003)
                       Accented Edges 16.1.2
                       Adaptive Wide Angle 16.1.2
                       Angled Strokes 16.1.2
                       Average 16.1.2 (2015.1.2 x001 x003)
                       Bas Relief 16.1.2
                       BMP 16.1.2
                       Camera Raw 9.5.1
                       Camera Raw Filter 9.5.1
                       Chalk & Charcoal 16.1.2
                       Charcoal 16.1.2
                       Chrome 16.1.2
                       Cineon 16.1.2 (2015.1.2 x001 x003)
                       Clouds 16.1.2 (2015.1.2 x001 x003)
                       Collada 16.1.2 (2015.1.2 x001 x003)
                       Color Halftone 16.1.2
                       Colored Pencil 16.1.2
                       CompuServe GIF 16.1.2
                       Conté Crayon 16.1.2
                       Craquelure 16.1.2
                       Crop and Straighten Photos 16.1.2 (2015.1.2 x001 x003)
                       Crop and Straighten Photos Filter 16.1.2
                       Crosshatch 16.1.2
                       Crystallize 16.1.2
                       Cutout 16.1.2
                       Dark Strokes 16.1.2
                       De-Interlace 16.1.2
                       Dicom 16.1.2
                       Difference Clouds 16.1.2 (2015.1.2 x001 x003)
                       Diffuse Glow 16.1.2
                       Displace 16.1.2
                       Dry Brush 16.1.2
                       Eazel Acquire 16.1.2 (2015.1.2 x001 x003)
                       Entropy 16.1.2 (2015.1.2 x001 x003)
                       Export Color Lookup Tables NO VERSION
                       Extrude 16.1.2
                       FastCore Routines 16.1.2 (2015.1.2 x001 x003)
                       Fibers 16.1.2
                       Film Grain 16.1.2
                       Filter Gallery 16.1.2
                       Flash 3D 16.1.2 (2015.1.2 x001 x003)
                       Fresco 16.1.2
                       Glass 16.1.2
                       Glowing Edges 16.1.2
                       Google Earth 4 16.1.2 (2015.1.2 x001 x003)
                       Grain 16.1.2
                       Graphic Pen 16.1.2
                       Halftone Pattern 16.1.2
                       HDRMergeUI 16.1.2
                       HSB/HSL 16.1.2
                       IFF Format 16.1.2
                       IGES 16.1.2 (2015.1.2 x001 x003)
                       Ink Outlines 16.1.2
                       JPEG 2000 16.1.2
                       Kurtosis 16.1.2 (2015.1.2 x001 x003)
                       Lens Blur 16.1.2
                       Lens Correction 16.1.2
                       Lens Flare 16.1.2
                       Liquify 16.1.2
                       Matlab Operation 16.1.2 (2015.1.2 x001 x003)
                       Maximum 16.1.2 (2015.1.2 x001 x003)
                       Mean 16.1.2 (2015.1.2 x001 x003)
                       Measurement Core 16.1.2 (2015.1.2 x001 x003)
                       Median 16.1.2 (2015.1.2 x001 x003)
                       Mezzotint 16.1.2
                       Minimum 16.1.2 (2015.1.2 x001 x003)
                       MMXCore Routines 16.1.2 (2015.1.2 x001 x003)
                       Mosaic Tiles 16.1.2
                       Multiprocessor Support 16.1.2 (2015.1.2 x001 x003)
                       Neon Glow 16.1.2
                       Note Paper 16.1.2
                       NTSC Colors 16.1.2 (2015.1.2 x001 x003)
                       Ocean Ripple 16.1.2
                       OpenEXR 16.1.2
                       Paint Daubs 16.1.2
                       Palette Knife 16.1.2
                       Patchwork 16.1.2
                       Paths to Illustrator 16.1.2
                       PCX 16.1.2 (2015.1.2 x001 x003)
                       Photocopy 16.1.2
                       Photoshop 3D Engine 16.1.2 (2015.1.2 x001 x003)
                       Photoshop Touch 14.0
                       Picture Package Filter 16.1.2 (2015.1.2 x001 x003)
                       Pinch 16.1.2
                       Pixar 16.1.2 (2015.1.2 x001 x003)
                       Plaster 16.1.2
                       Plastic Wrap 16.1.2
                       PLY 16.1.2 (2015.1.2 x001 x003)
                       PNG 16.1.2
                       Pointillize 16.1.2
                       Polar Coordinates 16.1.2
                       Portable Bit Map 16.1.2 (2015.1.2 x001 x003)
                       Poster Edges 16.1.2
                       PRC 16.1.2 (2015.1.2 x001 x003)
                       Radial Blur 16.1.2
                       Radiance 16.1.2 (2015.1.2 x001 x003)
                       Range 16.1.2 (2015.1.2 x001 x003)
                       Render Color Lookup Grid NO VERSION
                       Reticulation 16.1.2
                       Ripple 16.1.2
                       Rough Pastels 16.1.2
                       Save for Web 16.1.2
                       ScriptingSupport 16.1.2
                       Shake Reduction 16.1.2
                       Shear 16.1.2
                       Skewness 16.1.2 (2015.1.2 x001 x003)
                       Smart Blur 16.1.2
                       Smudge Stick 16.1.2
                       Solarize 16.1.2 (2015.1.2 x001 x003)
                       Spaces 16.1.2
                       Spatter 16.1.2
                       Spherize 16.1.2
                       Sponge 16.1.2
                       Sprayed Strokes 16.1.2
                       Stained Glass 16.1.2
                       Stamp 16.1.2
                       Standard Deviation 16.1.2 (2015.1.2 x001 x003)
                       STL 16.1.2 (2015.1.2 x001 x003)
                       Sumi-e 16.1.2
                       Summation 16.1.2 (2015.1.2 x001 x003)
                       Targa 16.1.2
                       Texturizer 16.1.2
                       Tiles 16.1.2
                       Torn Edges 16.1.2
                       Twirl 16.1.2
                       U3D 16.1.2 (2015.1.2 x001 x003)
                       Underpainting 16.1.2
                       Vanishing Point 16.1.2
                       Variance 16.1.2 (2015.1.2 x001 x003)
                       Virtual Reality Modeling Language | VRML 16.1.2 (2015.1.2 x001 x003)
                       Water Paper 16.1.2
                       Watercolor 16.1.2
                       Wave 16.1.2
                       Wavefront|OBJ 16.1.2 (2015.1.2 x001 x003)
                       WIA Support 16.1.2 (2015.1.2 x001 x003)
                       Wind 16.1.2
                       Wireless Bitmap 16.1.2 (2015.1.2 x001 x003)
                       ZigZag 16.1.2
                    Optional and third party plug-ins: NONE
                    Plug-ins that failed to load: NONE
                    Extensions:
                       Recent Files  1.2.0
                          C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_2_0_903\index.html
                       Libraries  2.3.1048
                          C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_3_1048\index.html
                       Start  1.2.0
                       Adobe Color Themes  6.1.0
                          C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html
                       Export As  2.4.0
                          C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.webpa.crema\PSPanel\dialog.html
                       Device Preview  1.1.3
                          C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.preview\PSPanel\panel.html
                       Share on Behance  3.0.0
                          C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.behance.shareonbehance.html\index.html
                       com.adobe.preview.loader  1.1.3
                          C:\Program Files\Adobe\Adobe Photoshop CC 2015\Required\CEP\extensions\com.adobe.preview\PSLoader\loader.html
                       Export As  2.4.0
                    Installed TWAIN devices: NONE
                    Thank you!
                    • 8. Re: Error: OWLPanelManager.cpp : 3936 : REQUIRE failed
                      Yes I see. I loaf more  then you.  still I see thing I fee is strange in you config.  Your video driver is a year older then mine and you onle have 22GB of scratch space.
                      In Mine I see:
                      Image tile size: 1028K
                      Image cache levels: 6
                      glgpu[0].GLDriverDate="20160318000000.000000-000"
                      clgpu[0].CLPlatformVersion="1.2"
                      Scratch volume(s):
                        F:\, 465.2G, 201.2G free
                        C:\, 224.2G, 131.9G free
                      In Yours I see:
                      Image tile size: 0K
                      Scratch volume(s):
