2 Replies Latest reply on May 21, 2016 11:13 PM by JR_Boulay
    Manually edit calculation result
    yeungyam
      I have a form that I want to be able to manually change the answer to the calculation. The objective is to accept a calculated value unless the user enters a different value in the calculated field. The calculated value will usually be the value desired, but not always.
      I have almost been able to achieve that by using multiple fields (as I only have basic knowledge of javascript), but there is just one problem where a value only appears one keystroke later. I am not even sure why as the other field is fine.
      I have attached the form for help: https://dl.dropboxusercontent.com/u/11052710/Adobe%20Acrobat/Overriding%20LVEF.pdf
