This content has been marked as final.
Show 9 replies
1. Re: getURL (*.pdf, "_blank");
boyBacon Jun 1, 2006 2:54 AM (in response to boyBacon)P.S. This problem seems to be IE-specific -
2. Re: getURL (*.pdf, "_blank");
TimSymons Jun 1, 2006 12:53 PM (in response to boyBacon)Yes. I have run into this issue and had to wrap the PDF in a HTML page and then call the HTML page which then called the PDF.
Tim -
3. Re: getURL (*.pdf, "_blank");
lenab Jun 1, 2006 1:14 PM (in response to boyBacon)I belive this problem is related to XP, not IE. You need to embed some code in your movie!. I don´t remember exactly where I read it, but it´s somewhere in this adobe-site, in the /devnet.
(Hope this will help you!) -
5. Re: getURL (*.pdf, "_blank");
boyBacon Jun 2, 2006 1:12 AM (in response to lenab)Thanks lenab! That may well be what I'm looking for....except that I'm running Flash 8 not MX2004 :-/ -
6. Re: getURL (*.pdf, "_blank");
lenab Jun 2, 2006 2:42 PM (in response to boyBacon)8 or mx, the problem is still XP! -
8. Re: getURL (*.pdf, "_blank");
boyBacon Jun 5, 2006 1:02 AM (in response to northstar_86)No, it doesn't.
Lenab -- I get that the problem is XP, but the hotfix in the link you've posted is for MX2004 -- I would have thought th\at if the problem was known about, then a hotfix wouldn't be needed for Flash8. : s -
9. Re: getURL (*.pdf, "_blank");
Phil Snyder Aug 12, 2006 9:26 AM (in response to northstar_86)Yes, it does work like a charm. Thanks!
