1 Reply Latest reply on May 20, 2016 9:12 AM by gkaiseril
    button field with two urls
    polyphilus
      I want to use a button field "Link" with 2 various links in combination with an option field "answer" (options: yes or no).
      If option field "answer" is on "yes", the button "Link" links to url1, if the user clicks on option “no”, this button field links to url2, if the user did not select anything, the button field "Link" should not forward to any urls. Can this be done by javascript?
        • 1. Re: button field with two urls
          Yes, one needs to use the "if" statement twice or a switch statement. You will first need to check to see if there has been a selection of one of the check boxes then if one of the buttons has been selected, you run the code for the appropriate selection. Using a switch statement you only need to test for the none selected, option 1, or option 2.
