6 Replies Latest reply on May 23, 2016 10:18 PM by tpk1982
    Replacing color with color value
    tpk1982 Level 4
      I am trying to remove a specific color and remove with another one. How i remove those with color value?
      var myColor;
      if(myColor ==  app.documents[0].colors.itemByName("PANTONE 287 C") ||  myColor ==  app.documents[0].colors.itemByName("Primary")){
          myColor.remove("C= 98 M= 75 Y= 7 K= 0")
      Karthi
        • 1. Re: Replacing color with color value
          tpk1982 Level 4
          Any suggestions please
          • 2. Re: Replacing color with color value
            AriEss Level 1
            Please try to explain more clearly what you're trying to achieve.
            Thanks!
            • 3. Re: Replacing color with color value
              S Hopkins Adobe Community Professional
              I think I understand what you are trying to achieve. If so, you will use remove (replacingWith) as in:
              var docRef = app.documents.item(0);
              var myColor = docRef.colors.itemByName("PANTONE 287 C");
              var replaceColor = docRef.colors.itemByName("C=98 M=75 Y=7 K=0");
              myColor.remove(replaceColor);
              Note: This also works with swatch references
              • 4. Re: Replacing color with color value
                tpk1982 Level 4
                Hi Hopkins,
                Thanks for your understanding. I have 20 different colors to be replaced with other 20 colors.
                if i do some thing like below it works:
                var myColor = docRef.colors.itemByName("Primary");
                myColor.remove("Black");
                but instead of giving name Black how i give the black values [0,0,0,100]?
                myColor.remove(docRef.colors.itemByName("C=0 M=0 Y=0 K=100"));
                Karthi
                • 5. Re: Replacing color with color value
                  natrev Level 3
                  Hi Tpk,
                  Try this code...
                  var len=app.documents[0].colors.length;
                    for(i=0;i<len;i++){
                        myColor=app.documents[0].colors[i];
                        if(myColor ==  app.documents[0].colors.itemByName("Primary")){// Primary is a color Name
                            myColor.remove(app.documents[0].colors.itemByName("C=98 M=75 Y=7 K=0"));//Replace Primary color and replace the color C98 M75 Y7 K0
                  • 6. Re: Replacing color with color value
                    tpk1982 Level 4
                    Hi natrev/Hopkins,
                    i missed the following things:
                    1) in my original coding i used space before values C=98 not C= 98
                    2) I have to mention the itemByname: remove(docRef.colors.itemByName("C=0 M=0 Y=0 K=100"));
                    Below coding is working fine:
                    myColor.remove(docRef.colors.itemByName("C= 0 M= 0 Y= 0 K= 100"));
                    Thank you so much of your help.
                    Much appreciated.
                    Karthi
