hello,
Is there a way to exit and reload an AIR iOS APP ?
I know the nativeApplication.exit() won't work on iOS.
I can't find a solution on the internet.
I hope someone can help me.
create a new main air app that loads your current app.
thanks voor the reply!!
But i figured it out how to do this.
i used the code:
var appDomain2:ApplicationDomain = new ApplicationDomain(ApplicationDomain.currentDomain);
var context2:LoaderContext = new LoaderContext(false, appDomain2);
var loader2:Loader = new Loader();
loader2.load(new URLRequest ("myMain.swf"), context2);
But it did"t works.
it did not work?
what problem did you see?
did you add your loader to the display list?
thanks for reply.
no, it did not work. I see that nothings happens. The loader will not open it.
How must i do it exactly add it to the display list? Because at the moment i can"t see the problem.
you need,
addChild(loader2)
oh okeeee!!
yes I did.
I don"t know wat te problem is. There is something I'm doing wrong.
is myMain.swf added to your included files?
Yes i did
i can't think of any other way to help via a forum.
someone will probably need to download your files to find the problem.
Thanks kglad .
I 'm sure now how to do it. That's great!! I think i must with a fresh brain look at it again.
At the moment i didn't see it. thanks a lot!!
you're welcome.
