4 Replies Latest reply on May 30, 2006 4:04 PM by Newsgroup_User
    2d to 3d
    Level 7
      Hi
      I have a Director MX2004 movie which allows users to create a floor plan and
      add furniture shapes in 2d, then display a 3d world shwoing the furniture in
      the "room".
      In the 3d world, I've created a plane and added a texture which is the 2d
      floorplan sprite as drawn by the user. Could someone advise how best to
      scale and position the floorplan and the furniture objects in the 3d world
      in the same relative positions as the user has put them in 2d?
        • 1. Re: 2d to 3d
          Level 7
          Charlie Allgrove wrote:
          > Hi
          > the "room".
          Hi. Two quick ideas comes to mind. Use spriteSpaceToWorldSpace()
          function to convert 2D coordinates into 3D or work with percentages.
          Suppose that your 2D floorplan sprite is 200x200 pixels, then 100 pixels
          = 0,5, 200px = 1 and so on...
          Now suppose that your 3D floorplan is made of 1500x1500 3d units. Then
          when the user clicks on the middle of the 2D sprite, that will be
          traduced as 0.5x0.5 of the 2D sprite, now you multiply that number for
          the 3D units (1500*0.5) and you get 750x750.
          You�ll probably have to apply offsets and make tweaks but the main idea
          is that you convert the 2D value to 0..1 by doing for example
          clickedPointX / float(spriteWidth) and then you multiply it by the with
          of the 3D floorplan.
          Hope that helps,
          Agust�n Mar�a Rodr�guez
          www.onwine.com.ar > Macromedia Director demos & code
          • 2. Re: 2d to 3d
            Level 7
            Thanks for that...I'll have a play and see how I get on!
            • 3. Re: 2d to 3d
              Level 7
              Hi
              I think I'm getting somewhere...but I'm new(ish) to Director and I'm not
              entirely certain about 3d units vs 2d units...
              I'm creating a plane in the 3d world and setting the width and length of the
              modelResource to a maximum of 320x240px with a scale of 1.
              Are these the 3dunits?
              I'm then taking the 2d positions of the furniture elements and converting
              them to the same point in the 3d world according to a calculated scale
              factor, but the positions do not appear to be correct...
              Any ideas gratefully received
              Charlie
              "Agust�n Mar�a Rodr�guez" <agustin@onwine.com.ar> wrote in message
              news:e5hh5j$bfh$1@forums.macromedia.com...
              >> Hi
              >> and add furniture shapes in 2d, then display a 3d world shwoing the
              >> furniture in the "room".
              >> world in the same relative positions as the user has put them in 2d?
              > Hi. Two quick ideas comes to mind. Use spriteSpaceToWorldSpace() function
              > to convert 2D coordinates into 3D or work with percentages. Suppose that
              > your 2D floorplan sprite is 200x200 pixels, then 100 pixels = 0,5, 200px =
              > 1 and so on...
              > when the user clicks on the middle of the 2D sprite, that will be traduced
              > as 0.5x0.5 of the 2D sprite, now you multiply that number for the 3D units
              > You�ll probably have to apply offsets and make tweaks but the main idea is
              > that you convert the 2D value to 0..1 by doing for example clickedPointX /
              > float(spriteWidth) and then you multiply it by the with of the 3D
              > floorplan.
              > Hope that helps,
              • 4. Re: 2d to 3d
                Level 7
                > Hi
                If you don�t have it, download and install 3DPI
                ( http://www.3dpi-director.com/). Use it for picking a model and change
                its position. Every time you press the increase/decrease button for the
                position value, you�re moving the model one 3D unit.
                It doesn�t have anything to do with the 3D sprite size. To know the
                boundaries of your 3D floorplan, move any model to the top left of the
                floorplan and watch its position in the 3DPI xtra, then move it to the
                bottom right position of the floorplan and check it�s position. You�ll
                get values like this:
                dummy model�s position when placed top left: vector(25, 80, 15)
                dummy model�s position when placed bottom right: vector(75, 180, 15)
                Suppousing you got those values, now you know that the floorplan�s
                width is 50 units (75 - 25) and its height is 100 (180 - 80).
                Now suppouse that you click on the 2D floorplan and you get 0.25 on X
                axis and 0.5 on the Y axis. With those values you can now find the 3D
                equivalent position:
                x_3D_pos = topLeft3DVector.x + floorPlanWidth * 2D_XclickedProportion
                x_3D_pos = 25 + 50 * 0.25
                x_3D_pos = 25 + 12.5
                x_3D_pos = 37.5
                and y_3D_pos would be 130, that is: 80 of offset + (100 of width * 0.5
                of 2Dfloorplan proportion).
                I hope this isn�t too messy for you.
                Regards,
