4 Replies Latest reply on May 24, 2016 4:08 AM by Johnwhite
    How to make the layer visible on and off
    Johnwhite Level 1
      Hi, experts
      this is my script:
              var docs = app.documents;
                   for (var i = docs.length-1; i >= 0; i--) {
                          docs[i].layers.item("Chi").visible = true;
                          docs[i].layers.item("Chi").locked = false;
                          docs[i].layers.item("Eng").visible = false;
                          docs[i].layers.item("Eng").locked = true;
            alert("Done.")
      but how can make the layer
      1. if the layer "chi" visible = true; while "eng" visible = false
      "chi" locked = false; while "eng" locked = true
      just to turn the
      layer "chi" visible = false; while "eng" visible = true
      "chi" locked = true; while "eng" locked = false
      just like two layer switch;
      regard
      John
        • 1. Re: How to make the layer visible on and off
          Sajeev Sridharan Level 4
          Try this,
              if(docs[i].layers.item("Chi").visible == true && docs[i].layers.item("Chi").locked == false)
                  docs[i].layers.item("Chi").visible = false;
                  docs[i].layers.item("Chi").locked = true;
                  docs[i].layers.item("Eng").visible = true;
                  docs[i].layers.item("Eng").locked = false;
              else if(docs[i].layers.item("Eng").visible == true && docs[i].layers.item("Eng").locked == false)
          alert("Done.")
          • 2. Re: How to make the layer visible on and off
            vinothr Level 3
            Couple of things to note:
            1. You should get layer by name layer.itemByName
            2. Consider reuse and error handling
            You can modify below code if you think your requirement is not translated.
            // Toggle between Chi and Eng layers
            function toggleLayers() {
                 var total = app.documents.length;
                 for(var i = 0; i < total; i++) {
                      var doc = app.documents.item(i);
                      var chiLayer = doc.layers.itemByName("Chi");
                      if(chiLayer && chiLayer.isValid && chiLayer.visible) {
                           lockLayer(doc, "Eng");
                           unlockLayer(doc, "Chi");
                      } else {
                           unlockLayer(doc, "Eng");
            // Lock layer and make it invisible
            function lockLayer(doc, layerName) {
                 try{
                      var layer = doc.layers.itemByName(layerName);
                      if(layer && layer.isValid) {
                           layer.visible = false;
                           layer.locked = true;
                 }catch(e) { }
            // Unlock layer and make it visible
            function unlockLayer(doc, layerName) {
                 try{
                           layer.visible = true;
                           layer.locked = false;
                 }catch(e) {}
            • 3. Re: How to make the layer visible on and off
              Loic.Aigon Adobe Community Professional
              Like this maybe ?
              var main = function() {
                var docs = app.documents,
                layers,
                n = docs.length,
                chi, eng;
                while ( n-- ) {
                layers = docs[n].layers;
                chi = layers.item("Chi");
                eng = layers.item("Eng");
                if ( chi.isValid && eng.isValid ) {
                eng.visible = chi.locked = !chi.visible;
                eng.locked = chi.visible;
              main();
              HTH
              Loic
              http://www.ozalto.com/
              • 4. Re: How to make the layer visible on and off
                Johnwhite Level 1
                Thank you all guys
                both are works, amazing.
                thanks appreciate.
                regard
                John
