3 Replies Latest reply on May 25, 2016 12:03 PM by WolfShade
    Trouble with cfspreadsheet and excel files
    mwoods1971 Level 1
      I have a request from a client to generate an excel spreadsheet from a query. I have the query kicking out the fields and I can generate the excel file without a hitch. The problem comes when the client takes that excel file and then tries to manipulate it. The majority of the trouble comes from fields that should be marked as currency or dates. I am, with some struggle able to generate a "real" date field. Before this Excel was not sorting the dates properly.
      I was able to call an excel formula by using this:
      <cfset SpreadsheetSetCellFormula(s,"DATEVALUE(#Chr(34)##Replacement_ETD##Chr(34)#)",therow,9)>
      Date value forces Excel to acknowledge this as a real date field. However, this fails when this file is manipulated thru excel. The next problem is the currency field. I can't get excel to acknowledge this as a currency. It always comes up custom. When this is set, the SUM function won't work in excel. You can add the fields individually like A1+B1+C1 = TOTAL. This won't be helpful when there are 200 rows.
      I was able to get a suggestion from another CF programmer who had a similar situation. He generated the excel file first with the proper headings and set the columns to their proper fields such as date and currency etc.
      The next step would be to fill in the fields row by row and they should be properly formatted.
      <cfset filename = expandPath("./reports/arrivals.xlsx")>
      <cfspreadsheet  action="read" src = "#filename#"  name = "s" >
                <cfset therow = 0>
                <cfoutput query="myExcel" startrow="1">
                     <cfset therow = myExcel.currentrow + 1>
                     <cfset SpreadsheetSetCellValue(s, Incumbent, therow, 1)>
                     <cfset SpreadsheetSetCellValue(s, Section, therow, 2)>
                     <cfset SpreadsheetSetCellValue(s, Position_Number, therow, 3)>
                     <cfset SpreadsheetSetCellValue(s, Position_Title, therow, 4)>
                     <cfset SpreadsheetSetCellValue(s, Incumbent_Emplyment_Type, therow, 5)>
                     <cfset SpreadsheetSetCellValue(s, Incumbent_ETD, therow, 6)>
                     <cfset SpreadsheetSetCellValue(s, Tour_Comments, therow, 7)>
                     <cfset SpreadsheetSetCellValue(s, Replacement, therow, 8)>
                     <cfset SpreadsheetSetCellValue(s, Replacement_ETA, therow, 9)>
      <cfheader name="content-disposition" value="attachment; filename=Departures_(#DateFormat(now(),'mmddyy')#).xls">
      <cfcontent type="application/msexcel" variable="#spreadsheetReadBinary(s)#" reset="true">
      The data in the cells has already been properly formatted. When this file is generated and streamed to the user the columns are not formatted as expected.
      Does anyone else know if this method will work or have a better suggestion on getting CF to generate a proper date and currency field for excel to acknowledge?
      Adobe ColdFusion v10 running on RHEL 5
        • 1. Re: Trouble with cfspreadsheet and excel files
          WolfShade Level 4
          For some reason, you have to format twice - once before the data is inserted, and once after.
          This is especially true if you have any data values that are strictly integers.  These, even if you format the cell ahead of time to be 'Text', will still align to the right, as integers do.  However, if you reapply the formatting after the data is inserted, then it should format properly.
          PS.. THANK YOU for taking the time to code for (cf)spreadsheetsetcellvalue!!  Too many people get lazy and just chuck a query object at a cfspreadsheet tag.
          • 2. Re: Trouble with cfspreadsheet and excel files
            mwoods1971 Level 1
            @WolfShade Thanks for the reply. One follow up.
            Are you talking about using SpreadsheetFormatCell or SpreadsheetFormatColumn? I have had some success with format column before but I still end up with data that the client still has issues with?
            • 3. Re: Trouble with cfspreadsheet and excel files
              WolfShade Level 4
              FormatCell, FormatColumn, FormatColumns, FormatRow, FormatRows.  If there is anything that Excel (or the CF workings for Excel) don't automatically format correctly, you'll most likely have to use the format twice.  Which could be slightly easier if you put all the formatting into a function and refer to the function once before populating the data and once after.
