2 Replies Latest reply on May 27, 2016 4:37 AM by e.d.
    Metadata tags creating markers
    e.d. Level 3
      I was wondering if there are any (preferably MXF) metadata tags that will be represented as markers when the file containing these is being imported to Premiere --- or is an XMP sidecar the only way to go here? The idea behind this is to (externally) consolidate the individual clips from a (flash) disk to a single file and have markers where the previously-single clips start.
        • 1. Re: Metadata tags creating markers
          Bruce Bullis Adobe Employee
          All markers, for all file types, are stored in XMP.
          Note: PPro stores XMP different places, for different file formats. However, if you use our get/setXMPMetadata() calls, your panel need not care where we save the metadata; it'll just work.
          How are you concatenating those multiple clips? Prelude can do that for you, as well.
          If your panel understands concatenating N little files into one large file, you can 'do the math' to create markers on the aggregated file, corresponding to where those markers would have been for the individual files.
          • 2. Re: Metadata tags creating markers
            e.d. Level 3
            Hi Bruce,
            I want to do this watchfolder-based using ffmpeg, so my shell script will need to take care of the math and put the xmp next to the concatenated file.
            Thanks for the info!
