1 Reply Latest reply on May 25, 2016 1:43 PM by Szalam
    i5930 vs i6700
    MisiSipos80 Level 1
      Hi there,
      I got two systems:
      system one:
      cpu i5930k H100i water cooled
      mobo: MSI x99a xpower
      gpu: evga gtx 980 ti hybrid
      ram: 32 gb corsair dominator.
      the system is overclocked to 4.5 ghz
      win 7 64 bit
      Rendered with newest cc media encoder, cuda engine
      system two:
      cpu: i6700 stock cooler
      mobo: asus  z170 pro gaming
      gpu: asus gtx 980 ti
      ram 8gb
      the system runs at 3.5ghz
      win 10
      Render with cs6 media encoder, cuda engine
      How is that possible that system 2 is out performed system one?
      I rendered the very same composition, with the very same settings and I got the following result:
      system one render time:  2 hours and 30 minutes
      system two render time: 56 minutes
      I spent a fortune on system one and it is quite an unpleasant surprise seeing that my system is out performed significantly by a weaker system.
      Any reason for that? Or is cs6 render engine is better than cc?
        • 1. Re: i5930 vs i6700
          You can download any of the following versions of AE: CS6, CC, CC 2014, and CC 2015 through the Creative Cloud app. Pick a version and install it on both of those machines to test rendering between them with the same versions. That way you can eliminate software differences and compare apples to apples.
