1 Reply Latest reply on Jun 1, 2006 7:01 PM by pauland
    Syntax check and auto-format disagree
    pauland Level 4
      Flash 8 Pro: Well, I'm coding along quite nicely and decide to auto-format. Auto-format says the code has errors, the syntax check says there are none. I can run my code (though it's not doing what I want) without getting an error.
      Are there specific scenarios that cause the syntax check and auto-format to disagree?
      In just about every other development tool I've used, it will auto format regardless of errors, even if the formatting is messed up. it's a good aid to highlighting syntax errors! Why can't flash do the same?
      Paul
