7 Replies Latest reply on Dec 22, 2016 6:37 AM by Matthew J. Wagner
    Add images to existing Collection Lr
    skorg264 Level 1
      I'm hoping this is going to be understandable what I am trying to ask....
      Once a series of selected images has been imported into the LR catalog as a collection, is there a way to move the collection within the catalog to another collection within the catalog? I'm having a hard time figuring out how to import (I don't want to move the original images but just add to LR) to a collection that is already in LR. When I select the ADD icon, it doesn't allow me to choose a collection to add it to; it only imports into the catalog as a new collection.
        • 1. Re: Catalog
          The way I like to do it is to import the images in the folder they are already in if they are on my computer, or else import new images from a card and place them in a folder. Then it's easy to add images to any collection. Collections are not physical places on the hard drive, but rather an organizing mechanism within the Lightroom catalog.
          • 2. Re: Catalog
            skorg264 Level 1
            Jim:
            I'm not sure I follow. I understand what you are saying...but when I import I am not given the option to add the images to any collection whether importing from a folder on my External Drive or from my camera when using the 'Add' option at the top of the library module.  It just takes the images and makes a new collection.
            If it is giving me options then I'm not seeing it or understanding it.
            • 3. Re: Catalog
              Mohit Goyal Adobe Employee (Admin)
              Hi skorg,
              Well, Add is the option on the import windows which initially allows you to add images to the Lightroom catalog. Once you finish with that process then you can simply drag your images to the collections folder to where you want to add it and start the further editing.
              Hope it helps
              Regards,
              Mohit
              • 4. Re: Add images to existing Collection Lr
                99jon Adobe Community Professional & MVP
                In the LR Library you can right-click (control-click) on any collection and choose “Set As target Collection”
                That switches the plus icon from the Quick Collection to the named collection.
                Select any thumbnail(s) and press the B key to instantly add the photos to your target collection.
                You can have the same image in multiple collections. Think of them like playlists in iTunes where you can put the same music track into many play lists, but they all reference the same mp3 file on your disk.
                So you might have the same photo in a saved print collection, a book collection, a slideshow collection or for a specific event.
                3 people found this helpful
                • 5. Re: Add images to existing Collection Lr
                  dj_paige Level 10
                  To designate a Target Collection before you import, you go to the Collections panel in the Library Module, and right-click on the desired collection and select "Set as Target Collection". It will then have a + appended to the collection name to indicate it is the Target collection.
                  In the Import dialog box, you check the box Add to Collection (it's under File Handling) and this will add your imports to the previously selected Target collection.
                  If you ask me, it's easier to just drag and drop the photos into the desired collection after import.
                  2 people found this helpful
                  • 6. Re: Add images to existing Collection Lr
                    photo-enthusiast Level 2
                    I use the "Add to Collection" feature during import. This functionality no longer works, at least for me, since the last update.
                    • 7. Re: Add images to existing Collection Lr
                      Matthew J. Wagner
                      Same issue for me.  It's never worked on m LR CC.  Great idea but it just doesn't seem to do anything.  I still have to manually drag my images into the desired collection.
