1 Reply Latest reply on May 26, 2016 8:39 AM by mihai.udvuleanu
    Mask with Shape
    g_quest Level 1
      Anyone else having trouble using this feature since the update? It remains grayed out no matter what I do.
        • 1. Re: Mask with Shape
          mihai.udvuleanu Adobe Employee
          Hi Gregory,
          To be able to apply mask to a shape, you need at least two objects selected: the shape to be masked and the mask.
          The simplest use case is to create two shapes that overlap, select both of them and `Mask with Shape` should be activated.
          Does the issue reproduce on this simple use case? If not, could you describe the steps to reproduce it?
          Mihai
