2 Replies Latest reply on May 26, 2016 7:17 PM by ashimg23377171
    How to get roman numeral in TOC
    ashimg23377171 Level 1
      I have run into a brick wall wrt numbering.
      I have a cover page (no number), followed by a toc (need roman numeral), and chapters (arabic numerals).roman numerals.PNG
      I wish the numbering on the cover page to be in roman numerals.
      The workflow that i am followin to accomplish this is as follows:
      Select the page.
      Go to Layout -- numbering and section options
      In the dialog box, direct my attention to 'Document Chapter Numbering' and from the 'Style' dropdown select roman numerals.
      I was wondering if you cld help me point out where im going wrong here.
      Attached is the screenprint of my workflow.
        • 1. Re: How to get roman numeral in TOC
          BarbBinder Adobe Community Professional
          It looks like you are setting this up as a single file and not multiple files in an InDesign book file? If so:
          Guessing that you want to count the cover page but not see a number it...
          1. Right click on page 1 (or if I guessed wrong on page 2) > Numbering and Section Options
          2. Start page numbering at 1, Style: i, ii, iii, iv
          3. Right click the first page of the first chapter > Numbering and Section Options
            If you actually have a book with multiple InDesign docs, you handle the numbering from the Book panel menu, using the same steps:
            When you generate the TOC it will pick up the numbering style used on the pages.
          • 2. Re: How to get roman numeral in TOC
            Thank you v much Barb. That works.
            Just one quick query, How do i access the Book menu panel on InDesign that's installed in Windows.
