3 Replies Latest reply on May 26, 2016 12:25 PM by pixxxel schubser
    GREP help
    Rondo6666
      I've got a (hopefully) simple grep query.
      I'm attempting to create a script that will clean up a database before merging into a variable data document. All the problematic data is consistent, I just don't know how to write the text file so scripteditor will buy in. I'm editing the text file being referenced by the indesign script "FindChangeByList.applescript".
      Here's the mission:
      I need to replace the following text:
      with - Three Year Olds .......... 118 lbs."," Older .......... 124 lbs.
      Simple - right?
      Any help will be huge.
        • 1. Re: GREP help
          pixxxel schubser Most Valuable Participant
          To little informations!
          But this grep does what you described:
          search:
          (?<=\r)(Three Year Olds)\r(\d+)\r”,”\r(Older)\r(\d+)
          replace with:
          $1 .......... $2 lbs.”,” $3 .......... $4 lbs.
          • 2. Re: GREP help
            Rondo6666 Level 1
            Seems to have been just enough information!!
            I think we're really close.
            I'm using this syntax:
            grep{find what:"(?<=\r)(Three Year Olds)\r(\d+)\r","\r(Older)\r(\d+)"}{change to:"$1 .......... $2 lbs.$3 .......... $4 lbs."}{include footnotes:true, include
            But applescript is apparently getting confused by the "," text. Can it be protected somehow?
            set properties of find grep preferences to {find what:\"(?<=\\r)(Three Year Olds)\\r(\\d+)\\r\",\"\\r(Older)\\r(\\d+)\"}
            set properties of change grep preferences to {change to:\"$1 .......... $2 lbs.$3 .......... $4 lbs.\"}
            (Note the ",\")
            • 3. Re: GREP help
              I'm not familiar with AppleScript.
              Does this Javascript works for you (standalone) ?
              Try it on a copy of your document.
              app.findGrepPreferences = null;
              app.changeGrepPreferences = null;
              app.findGrepPreferences.findWhat = '(?<=\\r)(Three Year Olds)\\r(\\d+)\\r(\”,\”)\\r(Older)\\r(\\d+)';
              app.changeGrepPreferences.changeTo = '$1 .......... $2 lbs.$3 $4 .......... $5 lbs.';
              app.activeDocument.changeGrep();
