3 Replies Latest reply on May 27, 2016 1:21 AM by TᴀW
    [JS SUI] How to set enter key event in listbox?
    K159 Level 1
      var w = new Window ("dialog");
      var myList = w.add ("listbox", undefined, ["one", "two", "three"]);
      myList.addEventListener ("keydown", function (kd) {pressed (kd)});
      function pressed (k)
          if(k.keyName == "Enter")
              var idx = myList.selection.index;
              alert(idx);
      w.show ();
      Hi.
      Only the enter key event does not working in this script.
      I want to occur enter key event and get index of listbox item.
      Any ideas?
      Thanks.
        • 1. Re: [JS SUI] How to set enter key event in listbox?
          Ronald63 Level 4
          Try this ...
          w.addEventListener ("keydown", function (kd) {pressed (kd)});
                  alert(idx);
          w.show ();
          Regards
          • 2. Re: [JS SUI] How to set enter key event in listbox?
            Peter Kahrel Adobe Community Professional & MVP
            > Try this ...
            That doesn't work, Ronald.
            But the highly sophisticated approach of pressing various keys thinking 'You never know' did the trick again: Ctrl+Enter (on Windows) gives the desired result, both in K159's and in Ronald's version.
            In CS6, Enter works fine, so Enter not working is a CC problem.
            P.
            • 3. Re: [JS SUI] How to set enter key event in listbox?
              TᴀW Adobe Community Professional & MVP
              Couple more observations:
              1. The original script works if you press Shift-Enter, or Ctrl-Enter. (Edit: Peter beat me to it!)
              2. Changing the event from "keydown" to "keyup" makes it work (though not repeatedly on the same list item unless the selection is changed in-between, which is a little strange).
              Ariel
