6 Replies Latest reply on May 29, 2016 7:04 AM by eddiee1993
    Need help Scripting
    eddiee1993
         I am a beginner at scripting, coding, and web design. I have been having questions regarding scripting.
      I need help developing an Adobe Script that will 1)Automatically open a PDF file I have (created in Illustrator CC 2015)
        2) Automatically change the name of two swatches,  to new names I have
        3) Save with same file name plus "_Z.PDF" at the end
        4) Then close the file.
        • 1. Re: Need help Scripting
          moluapple Level 4
          So you mean you've saved all your pdf file with "Preserve Illustrator Editing Capabilities" option checked on? You can start from here.
          // 1)
          var f = new File('path/to/filename.pdf');
          var doc = app.open(f);
          // 2)
          doc.swatches.getByName('swatch_1').name = 'new_swatch_1';
          doc.swatches.getByName('swatch_2').name = 'new_swatch_2';
          // 3)
          doc.saveAs(new File(f.fsName.replace(/\.pdf$/, '_Z.pdf')), new PDFSaveOptions());
          // 4)
          doc.close();
          • 2. Re: Need help Scripting
            eddiee1993 Level 1
            Thank you very much for your time and help. I tried running the script this way below but it says
            there is still an error in the part :  var doc = app.open(f);
            What should I do about this? I have it underlined below too in bold italics.
            function test()
                // 1)
                var thePath = "~/Desktop/";
                var theFile = "test_swatch_change.pdf";
                var f = new File(thePath + theFile);
                var newFileName = theFile.replace(/\.pdf$/, "_Z.pdf");
                // 2)
                doc.swatches.getByName('Kiss Cut').name = ('CutContourKiss-cut');
                doc.swatches.getByName('Through Cut').name = ('CutContourThru-cut');
                // 3)
                var saveFile = new File(thePath + newFileName);
                var saveOpts = new PDFSaveOptions();
                doc.saveAs(saveFile, saveOpts);
                // 4)
                doc.close();
            test();
            • 3. Re: Need help Scripting
              moluapple Level 4
              Just works fine here.
              try { var doc = app.open(f) } catch (e) { alert(e) }
              what's the error info?
              • 4. Re: Need help Scripting
                eddiee1993 Level 1
                It says its not a function. I think its app.open that they are referring too.
                • 5. Re: Need help Scripting
                  moluapple Level 4
                  Oh no, did you run it from ESTK and had not set target to illustrator?
                  • 6. Re: Need help Scripting
                    eddiee1993 Level 1
                    yes, it wasnt going through
