1 Reply Latest reply on May 31, 2016 6:36 AM by Bruce Bullis
    In XMP, is there a frame alternative to timeValue
    innerspaceouterspace Level 1
      Trying to set this value with the API, and I'd much rather set a frame value than a time value.
      In altTimecode:timeValue I'd like set 101 instead of 00:00:04:05 and in altTimecode:timeFormat, I'd like to set 'frames'
      However, manually setting these values through code doesn't work.
      Does Premiere only read in the values in this format?
      According to the spec, these are the possible values for this field:
          // Options are going to be (from xmp spec pdf):
              23976Timecode
              24Timecode
              25Timecode
              2997DropTimecode (semicolon delimiter)
              2997NonDropTimecode
              30Timecode
              50Timecode
              5994DropTimecode
              5994NonDropTimecode
              60Timecode
      But I'm hoping there's potentially another field, alternative field to altTimeCode:timeValue and altTimeCode:timeFormat. Otherwise, I have to convert them myself which I'm currently doing, I just think it would be safer to use frames like I've been doing already.
               <xmpDM:startTimeScale>24000</xmpDM:startTimeScale>
               <xmpDM:startTimeSampleSize>1001</xmpDM:startTimeSampleSize>
               <xmpDM:startTimecode rdf:parseType="Resource">
                  <xmpDM:timeValue>00:00:00:00</xmpDM:timeValue>
                  <xmpDM:timeFormat>23976Timecode</xmpDM:timeFormat>
               </xmpDM:startTimecode>
               <xmpDM:altTimecode rdf:parseType="Resource">
                  <xmpDM:timeValue>00:00:04:05</xmpDM:timeValue>
               </xmpDM:altTimecode>
