9 Replies Latest reply on May 30, 2006 9:29 AM by Newsgroup_User
    Text Fields.
    Level 7
      Im triying to use embed fonts that i inluded on the library* . Any one knows
      what to write on the code to make it work?
      I have this.
      myTextFormat = new TextFormat();
      myTextFormat.bold = true;
      myTextFormat.font = "Font_RusellSquare"; //It show on my font explorer as :
      Font_RusellSquare* // I used both and it doesnt work.
      myTextFormat.embedFonts = true;
      texto_intro_txt.text=Enter.t_text;
      texto_intro_txt.setTextFormat(myTextFormat);
      Anyone knows?
      Thanks!
        • 1. Re: Text Fields.
          Level 7
          Have you tagged the fonts in your library for export for action script and
          given them a linkage ID?
          Remove '_spamkiller_' to mail
          • 2. Re: Text Fields.
            Level 7
            Humm...
            I just did now, but it doesnt work.
            I exported for it actionscript.and i set the ID.
            And now Im using it like this??
            myTextFormat.font = Century_Gothic;
            or
            myTextFormat.font = "Century_Gothic";
            but still doesnt work. what do i do?
            Do iselect export for actionscript and then
            "Peter Blumenthal" <mmgroups@_spamkiller_PhageInteractive.com> wrote in
            message news:e5he41$7mt$1@forums.macromedia.com...
            • 3. Re: Text Fields.
              Level 7
              The one with the quotes:
              Is correct. So, Century_Gothic is the linkage ID you gave the font right?
              Can you perhaps zip and upload the FLA, and provide a link? I'll download
              and take a look. Specify also which version of Flash you are authoring in...
              • 4. Re: Text Fields.
                Level 7
                I would have to upload de xml and a lot of stuff. So im gonna try more just
                in case and then if i cant i can send that to you.
                Cheers!
                message news:e5hhp7$c6p$1@forums.macromedia.com...
                > in...
                • 5. Re: Text Fields.
                  Level 7
                  Sure. Or build a 'bare bones' demo where you simply create a text field,
                  assign an embedded font and set some text. This is a great way to get to the
                  bottom of your problem anyway, as it drastically reduces the number of
                  things it *could* be...
                  • 6. Re: Text Fields.
                    Level 7
                    I cant make it work...
                    do you have any fla using that? i could see you code and fix my thing...
                    cheers.
                    message news:e5hjf1$ebm$1@forums.macromedia.com...
                    > the
                    • 7. Re: Text Fields.
                      Level 7
                      Sure, here you go:
                      http://www.phageinteractive.com/Temp/simpleText.zip
                      Let me know how it goes...
                      • 8. Re: Text Fields.
                        Level 7
                        Thanks man!
                        It works i wasnt using create text box.
                        Now i went further and now i can use any embed font.
                        I have to create a text box somewhere of the screen and embed the font and
                        use the font i did import before.
                        So everything works now.
                        Cheers
                        message news:e5hok6$l09$1@forums.macromedia.com...
                        > Sure, here you go:
                        • 9. Re: Text Fields.
                          Level 7
                          Cool - you're welcome
