4 Replies Latest reply on May 29, 2016 4:38 AM by Obi-wan Kenobi
    How can I change the seize of space in an index sheet?
    martins71457202
      Hi there,
      I am using ID CS6 on Windows 7.
      Issue 1:
      My index file has three vertical columns containing all names from the book. The look I am trying to establish is:
      Horn, Johnny             25
      Hornblower, Allistair    49
      The invisible sign between words and numbers is ">>".
      The names should be left-aligned and the page numbers right-aligned. If I set the whole text to "right-aligned" this will work BUT:
      ID keeps making lines breaks even though there's enough room. This would look like this:
                               49
      The minimum space between words and numbers is obviously set too large.
      Where can I change this to prevent getting two lines instead of one?
      Issue 2:
      How I can I prevent ID to change the font everytime I update the index file?
      Thank you for your help.
