5 Replies Latest reply on Nov 12, 2017 2:52 PM by Evan.Robinson
    organizing presets?
    media kat Level 1
      All of my presets display in a long list. Is there a way to group presets or rank them or organize them so they are grouped based on usage, or something?
      Thanks.
        • 1. Re: organizing presets?
          WobertC Adobe Community Professional
          Presets will sort  "Numerical/Alphabetical"
          Global Presets can exist in Folders (that also sort numbers before letters)
          So you can have a folder for Basic Adjustments- call it "01 Basic"
          Another folder for Tone curve adjustments- call it "02 Tone Curves"
          Another folder for Calibrations- call it "03 Calibration"
          Then you should see something like-
          01 Basic
               Blacks +
               Exposure +1
               Exposure +2
               Whites -1
          02 Tone Curves
               021 Contrast low
               022 Contrast Med
               023 Contrast High
          03 Calibration
               Landscape
               Vivid
          Folders can be 'collapsed' which would the show in the Presets Panel as-
          01 Basic
          02 Tone Curves
          03 Calibration
          Even simply creating a folder called "ALL MY PRESETS" will place it sorted at the top of the presets list. ("A" alphabetically)
          And any presets you create- Place in this folder (and not the "User Presets" folder which is alphabetically near the bottom!)
          BRUSH Presets OTOH- cannot exist in sub-folders, so they can only exist in one long list. BUT again they will sort Numbers then letters, so  a Brush preset  001 will appear above one called AAA.
          And you can Re-name Presets; Right-Click.
          • 2. Re: organizing presets?
            ManiacJoe Adobe Community Professional
            As wobert points out, you can use two levels of grouping at the file system level:
            1 - A single level of folders can be used as the first grouping, alphabetical
            2 - Alphabetical file names
            For example, my presets look like this at the moment:
            • 3. Re: organizing presets?
              media kat Level 1
              1. Are there any issues with having too many presets installed?
              2. If I need to transfer everything from one Mac to another, can I simply copy the folder and subfolders that I placed all of the presets to another Mac?
              Thanks.
              • 4. Re: organizing presets?
                1. No issues. Just more difficulty finding one when you want to use it, therefore the need to use a folder structure to simplify.
                2. Yes. Copy and paste the folder of Presets.
                Note: Presets can be found in two places if you have ever used the option to "Store Presets with Catalog"
                a) In a sub-folder of the Catalog location.
                b) In a sub-folder of the system folders-  eg. C:\Users\Your Name\AppData\Roaming\Adobe\Lightroom
                • 5. Re: organizing presets?
                  Evan.Robinson
                  On Mac, the folder for global presets is /Users/Your Name/Library/Application Support/Adobe/Lightroom
                  There are separate folders for at least eight kinds of presets.
                  For Filter Presets, at least, if you have set "Store Presets with Catalog", it appears that presets in the Filter Presets subfolder do not show up in the filter menus, and folders in the Catalog location do not nest in the menus.  However, you can manipulate menu order by using leading characters (e.g. 'a -- Not Rejected', 'b -- Print Masters') in the filter names if you wish.
