8 Replies Latest reply on Jun 6, 2016 3:08 PM by Kevin Parrott
    I want to Export JPEG - Applscript
    karthickm50893796 Level 1
      1 } Here is my Applescript , I want to save without .ai i don't  why its coming with _JPEG ( i need "filename_JPEG.jpg" - i am getting "filename.ai_JPEG.jpg") if u run this applescript u came understand..
      set saveLocation to ((path to desktop) as string)
      set theFile to choose file
      tell application "Finder" to set fileName to name of theFile
      set fullPath to (saveLocation & fileName)
      set extension to "_JPEG.jpg"
      set VectorPath to fullPath & extension
      tell application "Adobe Illustrator"
       activate
       export current document to file VectorPath as JPEG with options {class:JPEG export options, artboard clipping:true, quality:70, horizontal scaling:100, vertical scaling:100, antialiasing:false}
      end tell
      2} it is possible to export "filename_HIGH.jpg"
       activate
       export current document to file saveLocation as JPEG with options {class:JPEG export options, artboard clipping:true, quality:70, horizontal scaling:100, vertical scaling:100, antialiasing:false}
      end tell
        • 1. Re: I want to Export JPEG - Applscript
          Kevin Parrott Level 2
          try this
          tell (info for theFile) to set {_Name, _Extension} to {name, name extension}
          set fileName to text 1 thru ((get offset of "." & _Extension in _Name) - 1) of _Name
              activate
          end tell
          • 2. Re: I want to Export JPEG - Applscript
            its work good,
            But every time script ask to choose file. If i select any file that file name as been saved on file name include _JPEG
            Basically i want to export file to desktop and my file name should be current open document as file name with _JPEG
            • 3. Re: I want to Export JPEG - Applscript
              Small structure how i need applescript.....
              • 4. Re: I want to Export JPEG - Applscript
                this now creates a folder on the desktop, saves original ai file to it as well as jpg and pdf, for the
                pdf you will need to create a pdf preset.
                    open theFile without dialogs
                end tell
                    if the folder fileName of desktop exists then
                        activate me
                        display dialog "Folder with the sams name exists" -- buttons {"Yes", "No"}
                    else
                        set SaveFolder to make new folder at saveLocation with properties {name:fileName}
                        set aFolder to SaveFolder
                        set aPath to aFolder as text
                        set fullPath to (aPath & fileName)
                        set extensionJ to "_JPEG.jpg"
                        set extensionP to "_PDF.pdf"
                        set VectorPathJ to fullPath & extensionJ
                        set VectorPathP to fullPath & extensionP
                            save current document in file aPath with replacing
                            save current document in file VectorPathP as pdf with options {class:PDF save options, PDF preset:"TEST RIP"} with replacing --You must setup a PDF preset
                            export current document to file VectorPathJ as JPEG with options {class:JPEG export options, artboard clipping:true, quality:70, horizontal scaling:100, vertical scaling:100, antialiasing:false} with replacing
                            close document 1 saving no
                        end tell
                    end if
                end tell
                • 5. Re: I want to Export JPEG - Applscript
                  I am not understand how did u do this, can u teach me.......
                  only one change i need convert this to Batch Process please.... it is possible Kevin Parrott
                  • 6. Re: I want to Export JPEG - Applscript
                    this is a bit clunky, but it works, save this as an application, you can drop as many ai files on this as you wish
                    File-Export-File Format-Application
                    on open these_items
                        repeat with i from 1 to the count of these_items
                            set this_item to (item i of these_items)
                            set theFile to this_item as alias
                                set user interaction level to never interact
                            end tell
                                    activate me
                                    display dialog {"A folder with the name " & "- " & fileName & " -" & " already exists
                    it will be tagged as DUPLICATE." as text} buttons {"OK"}
                                    set name of folder fileName to fileName & "-DUPLICATE"
                                    set aPath to SaveFolder as text
                                    set PDF_Path to fullPath & "_PDF.pdf"
                                    set JPEG_Path to fullPath & "_JPEG.jpg"
                                        save current document in file PDF_Path as pdf with options {class:PDF save options, PDF preset:"TEST RIP"} with replacing --You must setup a PDF preset
                                        export current document to file JPEG_Path as JPEG with options {class:JPEG export options, artboard clipping:true, quality:70, horizontal scaling:100, vertical scaling:100, antialiasing:false} with replacing
                                    end tell
                                else
                                    end tell
                                end if
                            end tell
                        end repeat
                    end open
                    • 7. Re: I want to Export JPEG - Applscript
                      Thanks Kevin Parrott
                      Different between using PDF present,  see below i attached a script with out PDF present but its work fine.....
                      please check and explain why we are using PDF present!!!!!!!!
                      set PDF_Desktop to ((path to desktop folder) as string)
                        tell current document
                        save in file (PDF_Desktop) as pdf with options {class:PDF save options, preserve editability:true}
                        end tell
                      end tell
                      • 8. Re: I want to Export JPEG - Applscript
                        I prefer pdf presets as it gives me more control over what I want in the final PDF.
                        Place this into your scripts folder, this now deals with only the open document.
                        tell application "Adobe Illustrator" to set theFile to file path of document 1
                                save document 1 in file PDF_Path as pdf with options {class:PDF save options, view pdf:true} with replacing
                            end tell
                        end tell
