5 Replies Latest reply on Nov 4, 2016 3:12 PM by Obi-wan Kenobi
    Select several tables …
    Obi-wan Kenobi Level 5
      Hi all,
      I've written a little script that works fine after "manually" selecting several tables using the text selection where they are placed.
      I would like to play inserting a find/replace to find (through a "condition" I use to mark the group, via text) marked tables groups I would want to be treated!
      What I don't actually know is how to write the code that'll allow me to select the paras chain!
      My actual script:
      var mySel = app.selection[0];
      var myCurTable = mySel.convertToTable("\r",",");
            myCurTable.appliedTableStyle = "X_Table";
            myCurTable.clearTableStyleOverrides( true );
      I have this:
      I finally get this:
      To be clearer, I did this video:
      Thanks in advance!
        • 1. Re: Select several tables …
          I don't see how to catch together these "<0016>"!
          • 2. Re: Select several tables …
            Alright. Let's exaggerate a bit and do a search by Text with "<0016>" on your text selection.
            // Text is selected:
            var scopeOfInterest = app.selection[0];
            app.findTextPreferences = null;
            app.findTextPreferences.findWhat = "<0016>";
            var resultArray = scopeOfInterest.findText();
            if(resultArray.length >0)
                // to duplicate the first found table to a new text frame simply do:
                var newTextFrame = app.documents[0].layoutWindows[0].activeSpread.textFrames.add({geometricBounds : [0,0,100,100]});
                resultArray[0].duplicate(LocationOptions.AFTER , newTextFrame.insertionPoints[0] );
            // After that fit your text frame to contents, if the size of the table allows this.
            // And anchor the text frame to an insertion point right after your selection.
            • 3. Re: Select several tables …
              Good beginning!
              My problem I don't try to fix is that I want to catch "following" tables not each table!
              So, never one isolated table in the text, but 2, 3 or more!
              The parameter is: I catch this table because it's followed by another or preceded by one!
              • 4. Re: Select several tables …
                You could do a search based on individual lines of text or paragraphs and write the table characters found to an array to keep them managable together.
                You could also do a label on a table with a numbering/naming scheme, that you can follow later after moving the table.
                The table in the found character "<0016>" is:
                foundCharacter.tables[0].label = "My text string or numbering scheme";
                foundCharacter.tables[0].insertLabel("Key string" , "value string, that is a naming or numbering scheme");
                If you then do a text search based on e.g. "<0016>" or gather your tables by other means, you could filter out the tables you are interested in.
                if(foundCharacter.tables[0].extractLabel("Key string") == "My table of interest 103" )
                { doSomethingWithThatTable(foundCharacter.tables[0]) };
                Or a bit more flexible:
                if(foundCharacter.tables[0].extractLabel("Key string").match(/10\d$/) );
                Note 1: Duplicating tables or copy/paste tables will also duplicate the applied labels.
                Note 2: .label = "String" is a special case of insertLabel() :
                .insertLabel("Label","Value"); is the same as .label = "String";
                Extracting a label value can be done like that:
                And as you already know, label values can be seen in the UI with the Script Label panel.
                Also labels with selected tables.
                • 5. Re: Select several tables …
                  Hi Uwe,
                  New learning about "Label" concept!
                  See you soon about my future tries!
                  Thanks for all!
