2 Replies Latest reply on Oct 10, 2006 5:58 AM by LifeBugs
    var in loop
    LifeBugs
      hello all,
      I have a action script class which is bindable and instantiates objects of other class
      as :
      quote:
      [Bindable]
      public class Templateobjects
      public var template1 = new sampleTemplate1();
      public var template2 = new sampleTemplate2();
      public function Templateobjects(){
      // constructor function
      and in my mxml file i import this class as and trying to access this variables in this class, as:
      import Templateobjects;
      public var templatelistObject:Templateobjects = new Templateobjects();
      for(var i:Objects in Templateobjects){
      trace(" found objects");
      i am not getting the trace...
      please tell me how should i go about this.
      Regards
      Mayur
        • 1. Re: var in loop
          inlineblue Level 1
          From the docs:
          ...you can use a for..in loop to iterate through the properties of a generic object...What you cannot do is iterate through the properties of an object if it is an instance of a user-defined class, unless the class is a dynamic class. Even with instances of dynamic classes, you will be able to iterate only through properties that are added dynamically.
          • 2. Re: var in loop
            LifeBugs Level 1
            Right i tried that and it worked ..
