7 Replies Latest reply on Jun 2, 2016 2:03 AM by Ann Bens
    M2T output
    martinpat1 Level 1
      Using PRE14 on a Mac.
      I want to export as an M2T file, but the slider only lets you select the low, medium and high quality settings when exporting to "Computer". I want to use my own bitrates etc but the "Custom" output doesn't include M2T, unlike previous versions. If I want to use my own settings, I have to export as mp4, mp2 etc.
      Have I missed something?
      Typical Adobe - forward one step, back two.
        • 1. Re: M2T output
          Could not find m2t either in the advanced settings
          Just out curiosity why do you want m2t.
          • 2. Re: M2T output
            What custom bitrate do you want to set it at -- and why?
            You can output an MTS/M2T file using Export & Share/Device/Computer 1920x1080.
            • 3. Re: M2T output
              martinpat1 Level 1
              Perhaps unnecessary, but I like to keep my outputs in the same format as the source, the bitrate of which falls between the medium and high-quality presets.
              I've also noticed another problem that has arisen in PRE14.
              If you go to Custom, Advanced Settings and select H.264 as the output, you get a list of mp4 settings in the Preset list. You can change the Basic Settings to create your own Preset. However, if you then go back to create another preset (or simply use one that appeared in the original list), you can't - the complete list has vanished and you're left with just the preset you created. You have to delete this preset to create another! In older versions, you could create as many user-defined settings as you wanted, and these would appear below the standard list.
              • 4. Re: M2T output
                Before we go on to another issue, are you satisfied with the answer to your first question? It can get clumsy to try to carry on two conversations in the same thread.
                • 5. Re: M2T output
                  Keeping it the same as the source depends on what you are going to do with the file.
                  Is it to archive, for the web, dvd, bluray???
                  Archiving requires a different format then putting it on e.g. Youtube.
                  • 6. Re: M2T output
                    martinpat1 Level 1
                    Satisfied in so much as I know it's not possible to export as a user-defined m2t file; unsatisfied that this is not an option as in previous versions!
                    I'm saving as an m2t file both for archiving and for burning to blu-ray.
                    I'll post the other problem in a new thread.
                    • 7. Re: M2T output
                      Best is to burn to Bluray with H.264. Its a far better codec and less artifacten.
                      For archiving, if one has enough storage, a format with a lossless codec.
