2 Replies Latest reply on Jun 1, 2016 12:55 AM by Nanaky
    Error getting license
    bones2016
      I have a problem downloading a book from the library to digital editions. It says:
      Error getting license. License Serer Communication Problem:
      E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
      Any help with this problem would be much appreiate thanks.
        • 1. Re: Error getting license
          bones2016 Level 1
          Thought I should add that I have re-installed the digital editions programme numerous too.
          • 2. Re: Error getting license
            Nanaky Level 5
            Windows:
                Close all applications.
                Choose Start > Run.
                In the Open text box, type regedit and then press Enter. The Registry Editor opens.
                In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
                Select the Adept key.
                Choose File > Export.
                In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
                Right-click the Adept key and choose Delete.
                In the Confirm Key Delete dialog, click OK.
                Close the Registry Editor.
                Open Adobe Digital Editions and reauthorize.
            Macintosh:
                quit Adobe Digital Editions.
                Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
                If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
