• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Snippets through selection
Community Beginner ,
May 31, 2016 May 31, 2016
I want to create snippets based on the text that I select in a topic. As I need to create a huge collection of snippets library, I was wondering if there is any feature or ready-made script available that helps me with converting individual table rows as snippets, it would save a lot of time for me in creating snippets. Can anyone please guide me on this?
Views
244
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jun 01, 2016 Jun 01, 2016
Hi there
Unfortunately, my crystal ball appears to be cracked and my psychic skills are sub-par today. As a result, I'm unable to divine the version of RoboHelp you may be using.
In later versions of RoboHelp, you have the capability of selecting across a block of text, right-clicking and choosing to Add to > Snippets.
Kind of curious about why the need for as many as you think you may be needing though.
Also, if your goal is to have a snippet be a row of a table, I'm not sure that you will be able to realize that goal. I note that when I have a table and select the row, the context menu DOES present the Add to bit, but Snippets is disabled (or greyed out as so many like to refer to it). So even if you were able to get a table row added as a Snippet, it likely wouldn't work well to seamlessly insert into an existing table or even append onto an existing table.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Community Expert ,
I found the same as Rick but wondered if you could create the snippet and then add the table directly into the snippet, maybe at HTML level. However, like Rick, I think it might not insert neatly into another table. A bit of trial and error in a dummy project maybe?
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
Yeah, I just tested this in a dummy topic. I had inserted a table consisting of two rows by two columns.
Then I added some text to each column of one row.
I then selected the row and changed to HTML view. Copied only the TR down to the /TR tags.
Added that to a snippet. I had to simply switch to HTML view in order to add it.
Upon adding the snippet to the existing table, it wasn't quite what I'd hoped.
Cheers... Rick
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Annnnd here's how it behaved if I just created a single row two column table in the snippet.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
