• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Parallel CFB3 and CFB2016 installs?
New Here ,
Jun 01, 2016 Jun 01, 2016
Possible to load both environments on the same Windows workstation?
I have several production apps going and I'm a bit nervous about making the jump.
TOPICS
Builder
Views
433
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 01, 2016 Jun 01, 2016
Sure, I do it. They could probably even share the same workspace and projects (can’t recall if I’ve done the former, I have definitely imported projects from one release into a later one).
Then again, you mention concern about production apps. What do you fear could happen to your code based on issues in the IDE, even if there were any? (Or is it that you use CFB against a CF server where you have no dev or test version, so any problem that DID happen to code would “affect production”?
/charlie
Votes
Translate
Translate
Community Expert ,
/charlie
/Charlie (troubleshooter, carehart.org)
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Charlie, that's good enough for me.
I had experienced some weirdness in CFB3 Mobile projects switching back and forth between PhoneGap config in the IDE vs config.xml, so just a little nervous. Speaking of which, if you project properties instead of setting up a config.xml file, where are the configurations stored when exporting?
J
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Can you reword that last question? I’m not successfully parsing what it seems you meant.
/charlie
Votes
Translate
Translate
Report
Report
Resources
Documentation
