5 Replies Latest reply on May 29, 2006 8:58 PM by kglad
    Rotated input
    caraie
      sorry my bad english isn't my first language.
      i'm trying to do a rotated form (with some grades of inclination) but if i try to rotate the inputs, this inputs disappear in the exportation.
      Maybe i can do this with AS but my skill level is no good
      how can i do it?
      thanks and sorry again!
        • 1. Re: Rotated input
          you need to embed the font of your textfield.
          • 2. Rotated input
            caraie Level 1
            Hi Kglad and thanks for the response:
            i try with this action script but without good results:
            quote:
            text.embedFonts = true;
            text._rotation = 45;
            I don't know what i'm doing wrong
            Thanks again!
            • 3. Re: Rotated input
              if you're going to embed a font using actionscript you have quite a bit more work to do. first, you must add a font to your library (click on the upper right of your library panel, click new font, select the font you want to use and click ok), then you must right click that font, click linkage, tick export for actionscript, assign a linkage id (say, yourFont) and click ok.
              then in your actionscript panel you can use:
              • 4. Re: Rotated input
                caraie Level 1
                Hi and thanks again Kglad,
                i solve the problem with your code and using in the input field the button "character..." and embeding the characters "a..z" "A..Z" and "Ññ"
                Thanks for the time and the patience!
                • 5. Re: Rotated input
                  you're welcome. but if you embed the font in the authoring environment you don't need to add that font to the library and embed it using actionscript.
