This content has been marked as final.
Show 5 replies
1. Re: Issue installing CF7 on server with Crystal...??
elDonrico May 31, 2006 5:28 AM (in response to RDJ)one thing to keep in mind is that crystal server 10 uses an SQL server for organizing enterprise documents and assets. i have found issues when you install crystal after you install other software that also use an SQL server... this, i think, has to do with the very lite version of SQL that crystal uses.
But, CF doesnt have an SQL server in use. and really doesnt have anything that would seem to interfere. i suggest taking note of all your crystal settings and dsn configs, just in case, but... i think it would be fine. Is this on a 2003 or 2000 server? (not that i think it would matter.) -
2. Re: Issue installing CF7 on server with Crystal...??
elDonrico May 31, 2006 5:30 AM (in response to RDJ)also, is this Crystal or Business Objects? -
3. Re: Issue installing CF7 on server with Crystal...??
RDJ May 31, 2006 5:48 AM (in response to elDonrico)The setup is a 2000 OS, already have SQL 2000 installed and in use too, It is Crystal Reports via Business Objects I believe.
Thanks for your insight,
Ron -
4. Re: Issue installing CF7 on server with Crystal...??
elDonrico May 31, 2006 6:23 AM (in response to RDJ)i really dont see a problem here. give it a try. -
5. Re: Issue installing CF7 on server with Crystal...??
elDonrico May 31, 2006 6:24 AM (in response to RDJ)i would get a tape backup first if you can... just in case.
