2 Replies Latest reply on Jun 2, 2016 11:15 PM by Mylenium
    After Effects Composition
    marcs29248102
      Do I need After Effects to use a .ae file in premiere? My DP is sharing his after effects composition with me via Google drive and I want to know if I need to have after effects to use this file in my premiere project.
        • 1. Re: After Effects Composition
          Dave LaRonde Level 6
          Yes.  And your guy  has to have an AE version that matches your AE/PP versions as well, or it won't work.  And if they're older versions, they may not work at all together.
          Not to mention you'd need all the source footage as well.  And you'd probably have to reconnect the media.
          Are you SURE you want to try this stunt?  Why not just have the guy render out his AE work?
          • 2. Re: After Effects Composition
            Agree with Dave. No offense, but your "I have no clue" question is a clear sign that you are entering dangerous territory and should not even think of it if you are on a deadline. You'd quite likely be in all kinds of trouble getting things to work the way you want.
            Mylenium
