9 Replies Latest reply on May 30, 2006 9:23 AM by ntsiii
    SQL Server 2005 Endpoints
      I am trying to fetch data from SQL Server 2005, bypassing IIS. SQL 2005 Endpoints require a username and password and don't support anonymous access. How can I send a username and password for authentication? This is the Flex 2 Beta 2 code I am using to call the service:
      <mx:WebService id="zoban" wsdl=" http://zoban/Library?WSDL">
      <mxperation name="GetBooks">
      Well, this does not work. If I point my browser to the service I get the username popup - prompt.
      Can I squeeze in something like <mx:username> and <mxassword> in the flex code?
        • 1. Re: SQL Server 2005 Endpoints
          ntsiii Level 3
          I haven't used that technology yet. How does SQL server expect the username and password? Do they need to go in the request object?
          Can you include them in the url if you call direcly from a browser?
          • 2. Re: SQL Server 2005 Endpoints
            poonamsheth Level 1
            here is some help for u,, if it solves ur problem?, but logic needs to be understood.
            pART 1 --- aBOUT aUTHENTICATION
            When a destination is not public, you can restrict access to a privileged group of users by applying a security constraint in a destination definition in the Flex services configuration file. A security constraint ensures that a user is authenticated, by using custom or basic authentication, before accessing the destination. By default, Flex Data Services security constraints use custom authentication.
            Basic authentication
            Basic authentication relies on standard J2EE basic authentication from the web application container. To use this form of authentication, you secure a resource, such as a URL, in the web application's web.xml file. When you use basic authentication to secure access to destinations, you usually secure the endpoints of the channels that the destinations use in the web.xml file.
            The following example shows a configuration for a secured channel endpoint in a web.xml file:
            <web-resource-name>Protected Channel</web-resource-name>
            • 3. Re: SQL Server 2005 Endpoints
              poonamsheth Level 1
              Whats Custom authentication? is as below
              As an alternative to basic authentication, you can use custom authentication and create a custom login form in MXML to match the appearance of your application.
              For custom authentication, Flex uses a custom login adapter, known as a login command, to check a user's credentials and log a principal into the application server. A login command must implement the flex.messaging.security.LoginCommand API. You can register multiple login commands in the security section of the Flex services configuration file. The server attribute of the login-command element is used to perform a partial match against the value returned by the servletConfig.getServletContext().getServerInfo() method. The server value must be a case-insensitive match of an initial substring of this value or the entire string.
              You can use a login command without roles for custom authentication only, but if you also want to use custom authorization, you must link the specified role references to roles that are defined in your application server's user store.
              Flex Data Services includes login command implementations for Adobe JRun and Apache Tomcat, Oracle Application Server, BEA WebLogic, and IBM WebSphere, as the following example shows:
              <login-command class="flex.messaging.security.JRunLoginCommand"
              <login-command class="flex.messaging.security.TomcatLoginCommand"
              <login-command class="flex.messaging.security.OracleLoginCommand"
              <login-command class="flex.messaging.security.WeblogicLoginCommand"
              <login-command class="flex.messaging.security.WebSphereLoginCommand"
              • 4. Re: SQL Server 2005 Endpoints
                poonamsheth Level 1
                WELL NEXT WAS UR QUESTION OF using a query string parameter
                pART 2 Passing request data into Flex applications
                You can pass request data to Flex applications by using a query string parameter or defining flashVars properties in the HTML wrapper. When you use query string parameters, Flex converts them to flashVars variables and passes them to the application.
                Inside the Flex application, you access flashVars properties and query string parameters exactly the same way, but the way that you pass them to the Flex application is different:
                * The flashVars properties: You explicitly define the flashVars properties in the HTML wrapper that points to the Flex application.
                * Query string parameters: You attach query string parameters to the URL in the browser's target window and the Flex Enterprise Services 2.0 converts them to flashVars variables.
                Changing either the query string parameter or the flashVars property does not trigger a recompilation of the Flex application if you are using the Flex Enterprise server.
                To use flashVars or query string parameters inside your MXML file, you access the Application.application.parameters object. The parameters property points to a dynamic object that stores each parameter as a name-value pair. You can access variables on the parameters object by specifying parameters.variable_name. As with any variable, you can bind the parameters object's properties to a display control or modify the value and return it to another function.
                The following example defines the myName and myHometown variables and binds them to the text of Label controls:
                <mx:Application xmlns:mx=" http://www.macromedia.com/2005/mxml" creationComplete="initVars()">
                // Declare bindable properties in Application scope.
                private var myName:String;
                private var myHometown:String;
                // Assign values to new properties.
                private function initVars():void {
                myName = Application.application.parameters.myName;
                myHometown = Application.application.parameters.myHometown;
                <mx:Label text="Name: "/>
                <mx:Label text="{myName}" fontWeight="bold"/>
                <mx:Label text="Hometown: "/>
                <mx:Label text="{myHometown}" fontWeight="bold"/>
                When a user requests this application with the myName and myHometown parameters defined, Flex displays their values in the Label controls. The following URL passes the name Nick and the hometown San Francisco to the Flex application:
                To view all the flashVars properties, you can iterate over the parameters object, as the following example shows:
                for (var i:String in Application.application.parameters) {
                ta1.text += i + ":" + Application.application.parameters + "\n";
                Flex does not recompile the application if the request variables have changed. As a result, if you dynamically set the values of the flashVars properties or query string parameters, you do not force a recompilation.
                Query string parameters must be URL encoded. The format of the string is a set of name-value pairs separated by an ampersand (&. You can escape special and nonprintable characters with a percent symbol (%) followed by a two-digit hexadecimal value. You can represent a single blank space using the plus sign (+).
                The encoding for flashVars properties and query string parameters is the same as the page. Internet Explorer provides UTF-16-compliant strings on the Windows platform. Netscape sends a UTF-8-encoded string to Flash Player.
                Most browsers support a flashVars String or query string up to 64 KB (65535 bytes) in length. They can include any number of name-value pairs.
                • 5. Re: SQL Server 2005 Endpoints
                  poonamsheth Level 1
                  Plz review the API documentation for their web services to make sure a method exists that can retrieve the information you want. The API documentation for the web services is located at :
                  • 6. Re: SQL Server 2005 Endpoints
                    poonamsheth Level 1
                    Tutorial on Understanding Service Authentication
                    by Brian Deitte
                    Brian Deitte is an engineer on the Flex team and a very smart guy who worked on some of the "close-to-the-metal" features like SWCs and the web service proxy in Flex 1.0 and 1.5.
                    • 7. Re: SQL Server 2005 Endpoints
                      poonamsheth Level 1
                      there is something called, Proxy service too,
                      The Proxy Service, in which you define both web service and HTTP service destinations, has service-level configuration settings also
                      If the proxy must first contact an external proxy before getting access to the Internet, you can provide the location of that proxy as well as a username and a password.
                      The following example shows max-connections and external-proxy configuration:
                      • 8. Re: SQL Server 2005 Endpoints
                        poonamsheth Level 1
                        u need to use dataservices for query string parameters.
                        You CANNOT do synchronous calls. You MUST use the result event. No, you can't use a loop, or setInterval or even doLater. This paradigm is quite aggravating at first. Take a deep breath, surrender to the inevitable, resistance is futile.
                        There is a generic way to handle the asynchronous nature of data service calls called ACT (Asynchronous Call Token). Search for this in Developing Flex Apps doc for a full description, but here it is in a nutshell. This example uses HTTPService but will be similar for RemoteObject and WebService:
                        * First, create a function to handle the data return, like "onResult()"
                        * In the HTTPService tag, put this function name in the "result" property, passing in event.
                        * Invoke the call in script:
                        //invokes the call to the HTTP data service
                        var oRequestCallbject = app.mxdsGetData.send(oRequest); //we will use this string value in the result handler.
                        //Yes, you CAN set this AFTER you invoke send()
                        oRequestCall.MyQueryId = "WhateverIWanttoUseToIdentifyThisCall" ;
                        * In the result handler, which will be called every time the data service call returns, you identify what the returned data contains like this:
                        var callResponse = oEvent.call; //get the call object
                        //gets the value of this property you set in the call
                        var sQueryId = callResponse.MyQueryId; //will be "WhateverIWanttoUseToIdentifyThisCall";
                        You can use this sQueryId value in a switch to do the correct processing. Alternatively, you can pass reference to a handler function directly.
                        • 9. Re: SQL Server 2005 Endpoints
                          ntsiii Level 3
                          The forum ate some of the code:
                          var oRequestCall bject ...
