0 Replies Latest reply on Jun 3, 2016 9:26 PM by StrongBeaver
    Illustrator Layers to Classes ?
    StrongBeaver Level 3
      I need to export an SVG file whereas each path in the SVG file has it's own class.
      I'm hoping renaming layers or groups then running a script in existence exports the SVG file, with the options available in IllustratorCC and when reading the SVG file each path or group has the class name given in the layer name. Similar to how Photoshop Generator works, or use to work, you'd append the layer name with another name which would be the class name for the path.
      I'm unfamiliar with Grunt but was willing to learn due to this task which, correct me if I'm wrong, does exactly what I want, due to my unfamiliarity I was informed it doesn't do what I want ?
