13 Replies Latest reply on Jun 9, 2016 3:09 PM by Trevorׅ
    Apply Conditions to para/char styles with a "for" loop …
    Obi-wan Kenobi Level 5
      Hi all,
      That's the end of the script:
      scores = the_document.findGrep()
      for (i = 1; i < scores.length; i >= i++) {
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.appliedParagraphStyle = "para_AutoStyle" + (i);
      app.changeToGrepPreferences.appliedConditions = ["para_AutoStyle" + (i)];
      the_document.changeGrep();
      app.findGrepPreferences.appliedParagraphStyle = "char_AutoStyle" + (i);
      app.changeToGrepPreferences.appliedConditions = ["char_AutoStyle" + (i)];
      No problem with the creation of:
      para_AutoStyleX para style;
      char_AutoStyleX char style;
      para/char_AutoStyleX condition associated.
      What I want to do is apply:
      "para_AutoStyle1" condition to "para_AutoStyle1" para style;
      "para_AutoStyle2" condition to "para_AutoStyle2" para style;
      "para_AutoStyle3" condition to "para_AutoStyle3" para style;
      "char_AutoStyle1" condition to "char_AutoStyle1" para style;
      "char_AutoStyle2" condition to "char_AutoStyle2" para style;
      "char_AutoStyle3" condition to "char_AutoStyle3" para style;
      Missing something!! …
      Thanks for help!
        • 1. Re: Apply Conditions to para/char styles with a "for" loop …
          Vamitul Level 4
          see comments in code:
          //use var to declar all variables!!
          var scores = the_document.findGrep(true); //always always iterate from the back
          //please review "for" syntax on:
          //https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/for
          for (var i = 0; i < scores.length; i++) {
            //final note, it's always a good idea NOT to use Strings for appling paragraph styles
            //instead use indesign objects
            var pStyle=the_document.paragraphStyles.item("para_AutoStyle" + i);
            if (!pStyle.isValid){
            continue;
            scores[i].appliedParagraphStyle = pStyle;
            scores[i].appliedConditions = [("para_AutoStyle" + i)];
          • 2. Re: Apply Conditions to para/char styles with a "for" loop …
            Hi Vlad,
            Thanks for your answer!
            It seems find to me but I can't make it work!
            • 3. Re: Apply Conditions to para/char styles with a "for" loop …
              Trevorׅ Adobe Community Professional
              Hi
              What's the details of the findWhat of the findGrep?
              • 4. Re: Apply Conditions to para/char styles with a "for" loop …
                Hi Trevor,
                The script has created a set of "n" para styles called "para_AutoStyle1", "para_AutoStyle2", … "para_AutoStylen", with a set of "n" conditions with the same name. Idem about the "m" created char styles: "char_AutoStyle1", "char_AutoStyle2", … "char_AutoStylem", with a set of "m" conditions called with the same name.
                What I want to do in the last part of the script is to apply these conditions respectively to the para/char with these styles applied in the doc!
                So, the script searches all paras with "para_AutoStyle1", "para_AutoStyle2", … "para_AutoStylen" and applies respectively the conditions "para_AutoStyle1", "para_AutoStyle2", … "para_AutoStylen", then searches all the text with "char_AutoStyle1", "char_AutoStyle2", … "char_AutoStylem" and applies respectively the conditions "char_AutoStyle1", "char_AutoStyle2", … "char_AutoStylem".
                Maybe I'm wrong! would it be better to apply the conditions before?
                • 5. Re: Apply Conditions to para/char styles with a "for" loop …
                  app.findGrepPreferences.findWhat = "????????????????";
                  • 6. Re: Apply Conditions to para/char styles with a "for" loop …
                    Find format: "para_AutoStyle1" para style and change to format "para_AutoStyle1" condition;
                    Find format: "para_AutoStyle2" para style and change to format "para_AutoStyle2" condition;
                    Find format: "para_AutoStylen" para style and change to format "para_AutoStylen" condition;
                    Find format: "char_AutoStyle1" para style and change to format "char_AutoStyle1" condition;
                    Find format: "char_AutoStyle2" para style and change to format "char_AutoStyle2" condition;
                    Find format: "char_AutoStylem" para style and change to format "char_AutoStylem" condition;
                    • 7. Re: Apply Conditions to para/char styles with a "for" loop …
                      Oh dear, oh là là mon ami!
                      From your opening question it was clear what you want to do.
                      My question is you have the line scores = the_document.findGrep()
                      The grep must have been set somehow either by manually inserting it in the find grep panel or by scripting.
                      Clear so far?
                      If by scripting you would have used something like app.findGrepPreferences.findWhat = "????????????????";
                      But your would have had all those question marks between the quotes, you'd have something else right? What?
                      If you did some manual work on the find grep panel what did you type in by the find option?
                      Regards
                      Trevor
                      • 8. Re: Apply Conditions to para/char styles with a "for" loop …
                        Trevor (and Vlad),
                        I think I would not have written this line:
                        I've no concerned grep find/replace before this line! [not for this point!]
                        Maybe this has misled you!
                        My question is in fact: can I use a loop "for" to search format as "para_AutoStyle1", "para_AutoStyle2", "para_AutoStyle3", … "para_AutoStylen" and change format to the found text applying a condition with the same name?
                        • 9. Re: Apply Conditions to para/char styles with a "for" loop …
                          var doc, paraStyles, charStyles, numberOfParagraphStyles, numberOfCharacterStyles, autoStyle,
                              l, n, basePaga, baseChar, regXP, regXC, style, autoStyles, autoCondition, autoConditions;
                          doc = app.activeDocument;
                          basePaga = 'para_AutoStyle';
                          baseChar = 'char_AutoStyle';
                          paraStyles = doc.paragraphStyles;
                          charStyles = doc.characterStyles;
                          regXP = /^para_AutoStyle\d+$/;
                          regXC = /^char_AutoStyle\d+$/;
                          autoConditions = [];
                          autoStyles = [];
                          numberOfParagraphStyles = paraStyles.length;
                          numberOfCharacterStyles = charStyles.length;
                          while (numberOfParagraphStyles--) {
                              style = paraStyles[numberOfParagraphStyles];
                              // check if the styles is a desired style
                              autoStyle = style.name.match(regXP);
                              if (autoStyle) { autoStyle = autoStyle[0]; } else {
                                  continue; }
                              autoCondition = doc.conditions.itemByName(autoStyle);
                              if (!autoCondition.isValid) {
                                  continue; }
                              autoStyles.push(style);
                              autoConditions.push(autoCondition);
                          l = autoStyles.length;
                          for (n = 0; n < l; n++) {
                              app.findGrepPreferences.appliedParagraphStyle = autoStyles[n];
                              app.changeGrepPreferences.appliedConditions = [autoConditions[n]];
                              doc.changeGrep();
                          // Do the same for the char Styles !!!!!
                          // while / push / for
                          • 10. Re: Apply Conditions to para/char styles with a "for" loop …
                            P.s. don't forget to set the ChangeConditionsMode to acording to whether you want to add or replace the existing conditions.
                            Probably before the paragraph styles loop you would want:
                            app.changeGrepPreferences.changeConditionsMode = ChangeConditionsModes.REPLACE_WITH;
                            and before the character styles loop:
                            app.changeGrepPreferences.changeConditionsMode = ChangeConditionsModes.ADD_TO;
                            HTH
                            Trevor
                            • 11. Re: Apply Conditions to para/char styles with a "for" loop …
                              Ok this is a more generic implementation for greping any properties with a shared name.
                              I used a while instead of a for loop but you can still mark the answer as correct.
                              // https://forums.adobe.com/message/8793520#8793520
                              // A Generic method of applying changeGrep to mapped properties of items with a shared name
                              // By Trevor http://www.creative-scripts.com Custom Scripts
                               * [mapProperties description]  Maps items of the same name in 2 valid DOM collections
                               * @param  String   collection_1_Name  The 1st property to map for example paragraphStyles or characterStyles etc.
                               * @param  String   collection_2_Name  The 2nd property to map for example conditions, fillColor etc.
                               * @param  Regex    regX        A regex to filter the collections for example /^para_AutoStyle\d+$/;
                               * @return Object               {prop_1: filteredCollection1, prop_2: filteredCollection2};
                               *                                       filteredCollection1 is an Array of the the 1st collection items whose name matches the regX
                               *                                       filteredCollection2 is an Array of the the 2nd collection items
                               *                                                           whose names are the same of the items in filteredCollection1
                              function mapProperties(collection_1_Name, collection_2_Name, regX){
                                  var collection_1, filteredCollection1, filteredCollection2, l, doc, prop_1, prop_2, name;
                                  doc = app.properties.activeDocument;
                                  if (!doc) {
                                      exit();
                                  collection_1 = doc[collection_1_Name];
                                  l = collection_1.length;
                                  filteredCollection1 = [];
                                  filteredCollection2 = [];
                                  while(l--) {
                                      prop_1 = collection_1[l];
                                      name = prop_1.name.match(regX);
                                      if (!name) {continue;}
                                      name = name[0];
                                      prop_2 = doc[collection_2_Name].itemByName(name);
                                      if (!prop_2.isValid) {continue;}
                                      filteredCollection1.push(prop_1);
                                      filteredCollection2.push(prop_2);
                                  return {prop_1: filteredCollection1, prop_2: filteredCollection2};
                               * [grepMapped description]
                               * @param  String findProperty   name of the findGrepPreferences property
                               * @param  String changeProperty name of the changeGrepPreferences property
                               * @param  Object map            {prop_1 , prop_2};
                               *                                prop_1 is an Array of the the find collection items
                               *                                prop_2 is an Array of the the change collection items
                               *                                                           whose names are the same of the items in prop_1
                               * @param  Boolean findIsArray    If the mapped property needs to be in an array form like in the case of conditions
                               * @param  Boolean changeIsArray  If the mapped property needs to be in an array form like in the case of conditions
                               * @return void
                              function grepMapped(findProperty, changeProperty, map, findIsArray, changeIsArray){
                                  var l, p1, p2, doc;
                                  l = map.prop_1.length;
                                  while(l--) { // figure out for your self how to use a for loop instead of a while
                                      p1 = (findIsArray)? [map.prop_1[l]] : map.prop_1[l];
                                      p2 = (changeIsArray)? [map.prop_2[l]] : map.prop_2[l];
                                      app.findGrepPreferences[findProperty] = p1;
                                      app.changeGrepPreferences[changeProperty] = p2;
                                      try { // might get into trouble if there's no finds
                                          doc.changeGrep();
                                      } catch (e) {}
                              function zapEm(){
                                  var paraCondsMap, charCondsMap;
                                  paraCondsMap = mapProperties('paragraphStyles', 'conditions', /^para_AutoStyle\d+$/);
                                  charCondsMap = mapProperties('characterStyles', 'conditions', /^char_AutoStyle\d+$/);
                                  grepMapped('appliedParagraphStyle', 'appliedConditions', paraCondsMap, false, true);
                                  grepMapped('appliedCharacterStyle', 'appliedConditions', charCondsMap, false, true);
                              app.doScript(zapEm, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT,'Map Styles');
                              • 12. Re: Apply Conditions to para/char styles with a "for" loop …
                                Hi Trevor,
                                Thanks a lot for the time you've spent on my question!
                                I've not tested your codes yet! [I'm living in France!] Tonight! I'll promise I'll post comments asap! [great for my own learning!]
                                Thanks again!
                                • 13. Re: Apply Conditions to para/char styles with a "for" loop …
                                  Ok you might be living in France (not that I see the connection) but you can still mark the answer as correct and also the answer over here Find the first line of a table on each page when the table runs on several pages…
                                  Ta very much,
                                  Trevor
